How do you bleed a 2630's fuel system?
curt
09-08-2003 19:01:18
I need to bleed my 2630's fuel system. Can anyone tell me the proper steps to follow? I don't see a little primer lever like some tractors. Any help you men can give me will be greatly appreciated.
david val
09-09-2003 11:27:54
 Re: How do you bleed a 2630's fuel system? in reply to curt, 09-08-2003 19:01:18
fuel transfer pump should have a priming lever. if it doesn't, its either broken or non original pump. if you don't find the lever, you can pressurise the tank with low air pressure and open the bleed screw at the fuel filter base. when the filter is air free you can loosen the fuel pipe at the injection pump until air free fuel flows. then you can try to start.
david
