60 power steering locks.
JDJACK
09-08-2003 16:50:54
Have a JD 60 that power steering will lock after making a left turn and trying to turn back to straight ahead, it won't turn. Try it again and then it will move. It will only do this then it gets warm (pulling disc or plow). It doesn't do it very much, but gets scary. If just driving around using loader it will not lock up. Is there a common problem with these? Seals that are leaking?, and is it a big job? Thanks for any help. JDJACK
Fred
09-09-2003 07:32:06
 Re: 60 power steering locks. in reply to JDJACK, 09-08-2003 16:50:54
Yes, this is a frequent problem with the earliest (50, 60, 70) version of JD power steering. I remember neighbors back in the '50s having this problem with new "first numbered series" tractors with power steering. The IT shop manual on the 50-60-70 talks about this problem. The "Mr. Thinker" column in Green Magazine has had a number of questions regarding this problem. I agree with the responder who said "get the Power Steering Manual and follow the procedures."
Clooney
09-08-2003 18:52:52
JDJACK, while there are a few different reasons you could be getting that lock-up, the most prevalent reasons are worn pins [and or slots] in the actuating sleeve, or a misadjusted [or worn tip on the] operating sleeve set screw, or a worn actuating sleeve cam..
~Replacing those actuating sleeve pins isn't that difficult but might be a little difficult to re-adjust all the sleeve & set screw settings, end play settings, & cam spring tension without a good Deere power steering manual.
~You might be able to cover the problem & make it livable with a just an operating sleeve set screw adjustment then setting the flow control up a little. If those adjustments don't stop the problem you can try to bias the steering valve so the steering has a slight lead to the right, that will usually allow it to return through the spot that it hangs at without actually hanging up.
~My best suggestion would be to obtain the Deere power steering manual & read then follow the manual's power steering trouble shooting procedure. Those Deere power steering systems aren't that difficult to work on but without proper guidance & set-up procedures you can easily get into trouble while working on them...
[email protected]
F-I-T
09-09-2003 04:55:48
 Re: Re: 60 power steering locks. in reply to Clooney , 09-08-2003 18:52:52
JDJack:
I'd like to second the notion that this catching can be caused by worn pins and actuator cam surfaces. Mine did not really catch, it just felt tacky in two spots. The pins had flat spots on them and the there were flats on the actuator cam surface. I stoned these cam surfaces VERY CAREFULLY, just to blend them and smooth the transition. Then I replaced the pins. They drive out and press in. A word of caution here: They must fit in there VERY tight ! You do not want one of these falling out. Mine fit tight, but I put a small dot from my mig in two places at the head end of the pins to help secure them, as well as using thread locker.
Get, use, or find someone with a decent dial indicator and magnetic base. You can get by with .001" graduations, though I have a tenths indicator I use on close work. Set those endplays by the book and it will be fine. As was said, spin then pinion gear to an unworn spot to gain some tautness if you go that far.
I'm betting on your catching coming from the cam/actuator valve area.
Frank-in-Tallahassee
70D // 855 // VAC
ron in MN
09-09-2003 13:25:23
 Re: Re: Re: 60 power steering locks. in reply to F-I-T, 09-09-2003 04:55:48
F-I-T, I assume you mean "tenths of .001 graduations, right? A tenths indicator alone would have larger graduations than .001
F-I-T
09-09-2003 14:12:42
 Re: Re: Re: Re: 60 power steering locks. in reply to ron in MN, 09-09-2003 13:25:23
Ron:
In the gauge lab we used to say "1 or 2" and that meant .001". Saying a tenth meant .0001".
Old habits are hard to break.
F-I-T
ChuckW
09-08-2003 18:24:11
this is caused by worn place in the top gear and wear on the worm gear. This clearance can be improved by rotating the top gear 180 degrees. Also activating pins need to be reversed in the unit and possibly end clearance adjusted. There are about 5/6 areas that probably need attention.
gene
09-08-2003 18:23:53
this is normal for john deere power steering. one thing that has helped us over the years is to put a can of STP in the power steering unit. everyone i ever had done this.
Mark Scholten
09-08-2003 17:45:57
Mine does the same thing. Must be a common problem. When it locks up, give it a little jerk left again and it will free up. Not a big problem for me but I never use road gear like I used to when I was a youngun!!
I will fix mine eventually.
Good luck, Mark
