2010 brakes locking
Dave
09-08-2003 16:00:48
I have a 1965 2010. If left for a few weeks the brakes lock up (either wheel). If I'm going forward when I hit the brakes, I have to back up a little to free them. If I'm backing up, the opposite happens. One person at the JD dealer said I should lubricate them, another said I should make sure they are absolutely dry and clean. There is some rusty powder when I open them. It looks like maybe condensation takes place in there and causes rust.
Any first hand experience in solving this problem?
tominmo
09-08-2003 18:15:45
 Re: 2010 brakes locking in reply to Dave, 09-08-2003 16:00:48
Sounds like you need to take them apart and thoroughly clean and lightly lube the actuating parts. It's not too difficult to do but will take an afternoon. Hopefully, your internal parts aren't rusted to badly. Clean everything and lube sparingly so as not to contaminate the disks. Use a good moly-grease, not oil.
These are good tractors when taken care of.
Mike Young
09-08-2003 23:54:12
 Re: Re: 2010 brakes locking in reply to tominmo, 09-08-2003 18:15:45
I had the same problem. I finally got it solved for now. I dissembled the brakes, soaked all the parts (except the friction disks) in a rust solvent, wire wheeled and wire brushed all the parts, then back in the solvent. The ball bearings on one side of mine were rusty with a few pits, I polished them with emery cloth. then rinsed the gunk and grit off with gasoline before starting reassembly, when dry I used moly grease sparingly around the ball bearings and used some spray white lithium grease on the toggle assembly. they work great now. These old tractors work great but do require maintence. Mike
