How to remove HARD BLOCK?
MAD DUC
09-08-2003 15:12:25
I bought a power block for my 47A, and the previous owner filled it with "Hard Block". He did this to stop a water leak into the combustion chamber. I want to remove it and have the leak fixed correctly. Have been chipping it out slowly with a hammer and different punches. Any faster way?
Earl S.
09-10-2003 19:06:41
 Re: How to remove HARD BLOCK? in reply to MAD DUC, 09-08-2003 15:12:25
Why don't you contact "Hard Block" they have a Web. I am sure they can tell you how to remove it.I have never asked that, but they have been helpful with all the other questions I have had. Earl in Illinois
MAD DUC
09-13-2003 18:16:23
 Re: Re: How to remove HARD BLOCK? in reply to Earl S., 09-10-2003 19:06:41
Thanks Earl! I found their website and I am going to give them a call. But...on their product page it says that once it is hard, it can not be removed from the block. Looks like it might just be the hammer and punch routine. I'm about half way thru one cylinder.
Lee
09-09-2003 02:34:16
I'm not familiar with HARD BLOCK but it sounds like epoxy or similar compound. If so, just give the block to the machine shop and when they heat it up in their oven to attempt the repair the right way, the epoxy will burn off.
