420 Gear clunk, downhill only. Clooney, Anyone??
Wayne in Tn.
09-08-2003 14:19:19
Awhile back someone else posted with this same problem. Its a 4-speed-420. Going downhill only. It has a loud clunking in the transmission, sounds like 2 gears hitting each other, or like one is sliding downhill or forward and coming in contact with something. When going uphill its quiet as a mouse. I have inspected all gear teeth, wear on shifter and forks, no slack can be felt in shaft bearings. I just cannot see what can be making the noise. Hopefully someone that has had this problem will be able to point me to a certian gear or problem. Thanks- Wayne
Phil
09-08-2003 18:15:09
 Re: 420 Gear clunk, downhill only. Clooney, Anyone in reply to Wayne in Tn., 09-08-2003 14:19:19
We have a 40 that has what dad calls clatter under the same conditions as you describe and even in 4th when going down hill. It has done it since he first got it in the late 60's. Always did sound like it came from the transmission and have had the transmission case open several times and never found anything really wrong with it unless we were overlooking something. Sorry that doesn't help much but if someone has somewhere to look would love the info.
Henry J
09-08-2003 15:11:43
Wayne
Did you peep at the ring gear per chance? Also does it make the same noise in all the gears?
Wayne in Tn.
09-08-2003 15:21:12
 Re: Re: 420 Gear clunk, downhill only. Clooney, An in reply to Henry J, 09-08-2003 15:11:43
Have not looked at the ring gear, the noise seems to come from the front of the trans. It for sure does it in 2nd and 3rd and will do it with the clutch pedal depressed. I cannot say for sure it will do it in 1st or 4th as I was only using 2nd and 3rd to bushog with.
