Deere MT Arc from Starter Button
Duane Manning
09-08-2003 09:17:22
I have a JD MT which has been converted to a 12v system (by the former owner) with an alternator and the works and recently the battery died. The tractor is still positive ground. I replaced the battery with another 12v battery, and now when the starter rod connects with the starter button, sparks can be seen from the connection of the two. The tractor will still start and run fine. Any attempts to prevent the "sparking" (wrapping the connection with black tape to prevent metal to metal contact) results in the starter not working. My experience is very limited, what am I doing wrong?? Any comments are greatly appreciated.
Wayne in Tn.
09-08-2003 10:34:46
 Re: Deere MT Arc from Starter Button in reply to Duane Manning, 09-08-2003 09:17:22
Duane, If you are referring to sparks at the switch that sits on top of the starter, there should be no sparks there. Possibly some metal part of the starter rod mechanism is touching the (HOT) wire or post. If not, the switch itself may be damaged or grounded. Those switches are available new, from most auto part stores such as NAPA or Carquest.
Duane in TN
09-09-2003 09:23:49
 Re: Re: Deere MT Arc from Starter Button in reply to Wayne in Tn., 09-08-2003 10:34:46
The sparks are coming from the hinged part of the starter pull rod that actually touches and pushes the button on the starter. When I replaced the battery, I didn't make any changes to anything, that's what's got me confused. Thank you for your reply.
