2240 Steering Adjustment
Earl
09-08-2003 04:03:55
I have a JD 2240 with power steering that seems to have excessive steering wheel play. I can turn the steering wheel, back and forth, about 150 degrees before the steering components start to move. I checked/replaced all bushing, pins and ball joints in the steering linkage and front axle and the problem seems to be located in the steering gear itself. I have noticed the steering wheel raises up when I start to turn it. Is there an adjustment nut under the steering wheel that I can adjust to take some of the free play out of the steering? Thanks!
david val
09-08-2003 11:23:56
 Re: 2240 Steering Adjustment in reply to Earl, 09-08-2003 04:03:55
the steering valve should be repaird asap. probably broken con rod pin or loose piston.
david
Earl
09-12-2003 03:55:13
 Re: Re: 2240 Steering Adjustment in reply to david val, 09-08-2003 11:23:56
Thanks David! It doesn't look like I have a broken connecting rod. What do you mean by a loose piston? I have looked at the illustrated parts breakdown and it "looks" like a loose or improperly adjusted, adjusting nut, (under the steering wheel) would allow the steering mechanism to raise up when I turned the wheel in either direction, which would translate into "slop" or play in the steering wheel. I have never taken a JD steering mechanism apart, so, I could be way off base. Thanks!
