2010 diesel injection pump
Mike Young
09-07-2003 22:44:31
I am in need of someone that has instructions on rebuilding the roosamaster injection pump from a 61 2010 tractor. I have the gasket kit, and its leaking from the bottom of the pump into the crankcase diluting the oil and causing the oil pressure to drop allmost to 0. the tractor seems to run fine other than that. any help would be greatly appericated. Mike Young
Bob
09-08-2003 06:34:24
 Re: 2010 diesel injection pump in reply to Mike Young, 09-07-2003 22:44:31
Once you have removed the shaft from the pump, note EXACTLY how the seals are placed on the shaft, and CAREFULLY replace them. Stanadyne makes a tool for this, which is a plastic thimble that allows you to stretch the seals over the tool, and slide them into position, but it can be done without the tool. Use plenty of lube. The shaft will go back into the pump in 2 positions, 180 degrees apart, so BE SURE to note the timing marks, 1 in the slot where the shaft plugs in, and 1 on the tang on the end of the shaft. These must be aligned.
jdemaris
09-08-2003 06:00:16
If you can pull the driveshaft out of the pump, you won't need to disassemble it in order to fix the leak. In most John Deere applications using the Roosa Master DB or JDB pumps . . . when the pump goes on horizontally there is nothing holding the driveshaft in the pump, i.e. the pumps slides easily off the driveshaft. However, the 2010,1010, 4010, etc. use a vertically mounted pump. In this case there is usually an o-ring installed on the driveshaft that keeps it from falling out of the pump when it is removed. This o-ring serves no purpose other than keeping the shaft from falling out of the pump. If you're lucky, and can pull the shaft out, you can install the two new cup seals on it and reinstall it without the retaining o-ring. Otherwise, you will need to disassemble the pump. Also, keep in mind that the driveshaft and dual seals rides in a bronze bushing. If it is worn, it will need replacement and a new one is not included in the seal kit. On the subject of a repair manual . . . John Deere supplied one but it was not included in the 2010 manual. It was a manual specific to Roosa Master pumps and not on any one tractor. There are many other tractor manufacturers that did include full repair informatiion within manuals for specific tractors. So, if you have access to manuals for other tractors that also used the Roosa Master pump, you might find what you want. For example, I have an Allis Chalmers HD4 crawler that uses the Roosa Master pump and it gives detailed service information with a full set of photos in its manual. Also, someone recently posted information relating to an afermarket publication for repairing Roosa Master/Stanadyne pumps in these discussion groups withing the past week.
Jan
02-02-2004 14:47:43
 Re: Re: 2010 diesel injection pump in reply to jdemaris, 09-08-2003 06:00:16
I own a 63 2010 track loader that needs more expertise than I am able to throw at her. I have the repair manual FWIW. The machine (when purchased) was addicted to ether, so when she finally quit starting, I pulled the engine, renewing the cylinder plate, rings and mains. Also have replaced the fuel filters and had the fuel pump rebuilt (and then re-tested after no start with 40 psi result).
I am now in a confused state regarding what steps to take in what order to get her started. I have run down batteries going through the prime process stated in the manual. I have attempted to assure pump timing (DC on the flywheel, pump not 180 out, timing mark in its inspection cover visible, but not centerable), have rebuilt the primer pump (to intake).
I have a few questions that I need to get clear answers to before knowing if I am all done and own yard art, and probably several that I do not know to ask.
1. fuel pump has 2 fittings into its inlet... is one of these a return from the injectors? I note that there is a lower fitting that provides fuel return from the pump to the tank.
2. What is proper priming procedure when air is everywhere in the system?
3. Must the timing mark on the pump be centered? If it cannot be, what is the problem? The machine was running fine (other than crappy compression and bad glow plugs up to it dying)
4. The way it died seemed like a fuel delivery problem in that it was running great, working hard and when I went to park it and brought the throttle down to idle, she just died. I had difficulty starting her again for a couple of hours, then was able to do so. Used the machine a couple more days, then the same symptom, with the final result being no start, no matter what. When I started attempting to diagnose, I changed ancient fuel filters. They refilled wiht fuel nicely and all seemed good, except it didn't start. Then I had the pump rebuilt. No change. Then I rebuilt the engine. No start. New glow plugs and wiring. No start. Sigh.
If someone on this forum is willing to help me sort this one out, I am forever in your debt!
It is great to send email to me directly if you wish.
Thanks,
[email protected]
Kerry
02-11-2005 06:35:56
 Re: Re: Re: 2010 diesel injection pump in reply to Jan, 02-02-2004 14:47:43
Jan, did you ever get an answer to your 2010 problem? I have a 1964 2010 tractor that I rebuilt using a gas 2010 block and putting the diesel liner kit and pistons in it. Ran fine for around 300 hrs. One morning it would not start and I pulled the injection pump and had it checked and rebuilt. Had a time getting it fired up but it did and ran good for about 30 seconds. Sounded as if the air was being choked off. Haven't been able to start it since. I pulled the pump and they say it checks out good. When I bleed the lines for air, I don't seem to be getting enough diesel "push" out of the loosened line. I have new filter, pulled tank and checked for debri and checked free flow to pump. Adjusted valves and checked air filter and flow. New glow plugs and injectors checked out fine. Help!
jan nelson
06-15-2005 22:18:12
 Re: Re: Re: 2010 diesel injection pump in reply to Kerry, 02-11-2005 06:35:56
Yes, I fixed it. I had installed the oil pump without regard to its role in fuel injector pump timing. After setting it up properly, I still had trouble bleeding the system, so after rechecking the pump (checked out fine) I purchased a 12VDC fuel pump at Schucks and put in inline (just ahead of the injector pump) and used it to drive the bleeding process. Then after getting the rig to start, removed it. Crawler has been running great since.
