3-point hitch for a 1958 John Deere 520?
James Hurst
09-07-2003 22:18:02
Hi, I'm considering buying a 1958 John Deere 520. Does anyone know what's involved in putting a three-point hitch on these? What parts are needed, and is it straightforward or would it be better to just wait until I find one that already has it?
I am grateful for yall's help, thanx
Im
JDVan
09-07-2003 23:16:15
 Re: 3-point hitch for a 1958 John Deere 520? in reply to James Hurst, 09-07-2003 22:18:02
If the 520 had a 3 point hitch on it from the factory or was set up for a three point hitch from the factory, it is not too big a job to add one. They are a bit expensive however. $800 to $1,000 or more for the three point including elephant ears and anti-sway blocks. A complete original JD Top link may run over $300 although reproductions are available for less.
If the tractor did not come from the factory equipped for a three point hitch it is a huge job to add the Top link Yoke, shaft and whatever load and depth control linkage is required. I have done it on a 620 and it is a big job. If the tractor includes the top link Yoke you can add a 3 point quite easily. W/o one, buy another tractor that has one on it.
Dennis
09-08-2003 18:17:05
 Re: Re: 3-point hitch for a 1958 John Deere 520? in reply to JDVan, 09-07-2003 23:16:15
JD,
I just bought a 620 and want to add the 3 point. Would you be so kind to tell me what to watch out for as I proceed. You can email me at [email protected] to short circuit the process if you like.
Dennis
