310B engine rebuild info
Ron Bailey
09-07-2003 20:02:15
I have my back hoe engine takin apart for a rebuild. I removed the cylinders to install new o-ring. Was pretty simple. Is there any thing I might need to know when installing the cylinders... Any tips or recommends you might want to give me... Like do I need to put a bead of silcon around the o-ring..
I also need to know what to torque the rodcaps bolts to and the head bolts to...
Any info will be appreciated !!!
Thanks Ron
John
09-08-2003 03:51:24
 Re: 310B engine rebuild info in reply to Ron Bailey, 09-07-2003 20:02:15
I dont have the torque specs. But for advice I can say that Ive used liquid ivory soap to lube the o-rings successfully. And as each sleeve is installed use a short bolt and washer oin a close headbolt hole to hold the sleeve down. That way the ring friction wont lift it out of place while turning the crank for rod cap tightening.
