Gas or tractor fuel
Wes
09-07-2003 19:24:12
In my latest tractor magazine there are some references to converting from tractor fuel to gas. What is the conversion. I have done nothing to my 47 A to convert it but I still run gas. Am I hurting my engine? Oil pressure is normal and operating temp is around 180 on a heavy load. All help is gratly appreciated.
john
09-09-2003 22:00:09
 Re: Gas or tractor fuel in reply to Wes, 09-07-2003 19:24:12
I always get a big kick out of the folks at tractor pulls buring 100LL or race gas in their antique stuff. Wasting money and actually loosing power. If it was made to burn distillant (ie 4.5 - 1 compression) then it will actually make more power on the lowest octane junk you can buy. Will almost run on straight diesel. Even as much as 50% fuel to gas will work without knock. If it doesnt have the compression to make use of the good stuff, you are wasting time and money. As far as the valves burning, do you actually use it that much? Most of us never get the exhaust temp up enough to even hurt the valves. Put a little ATF in the tank if you actually work the tractor hard and don't want to have to do a valve job after 3000 hours. Otherwise, I wouldn't really worry about it and buy the cheapest gas I could find.
SamH
09-08-2003 05:34:27
A gas burner has higher compression pistons, different carb and manifold, etc. If the tractor is running to suit you, there's no point in changing all that stuff.
Pappy
09-07-2003 22:27:36
When heavier fuels were cheaper, (Kerosene-Distilate, etc) it was more economical to run the tractor on these fuels. Gasoline was expensive, comparatively. Now, heavier fuels are not economical and gasoline gives better performance.
Run ordinary gasoline in the tractor. No Problem!
Mark Scholten
09-08-2003 04:04:28
 Re: Re: Gas or tractor fuel in reply to Pappy, 09-07-2003 22:27:36
Regular gas is fine, but shouldn't we be adding a lead additive to lubricate, in our case, the front end? Mark Scholten
Jason D. Wahl
09-08-2003 15:00:49
 Re: Re: Re: Gas or tractor fuel in reply to Mark Scholten, 09-08-2003 04:04:28
It is a good idea if you can afford it to use a lead subsitute in your gas as the old engines loved it. Lead is a very good source of lubrication, especialy for the valves. However, the world will not end if you never use it. Using a higher octane gas usually provides a little cleaner burn and a bit more power resulting in better performance and less carbon build up in your engine. As always, use fresh gas only! Todays gasolines do not have the lubrication packages in it compared to the old formulas. After eighteen days, today's gas is no longer potent.
buickanddeere
09-08-2003 19:50:47
 Re: Re: Re: Re: Gas or tractor fuel in reply to Jason D. Wahl, 09-08-2003 15:00:49
I'm not trying to offend anyone here but I have to disagree with a few points here. The lead oxides did provide an layer of material on the cool valve seat and some on the hotter valve.If your engine is an air cooled radial aircraft engine running wide open throttle for take off. And cruising at rated continuous power with the mixture leaned out.The white hot valves and red hot seats will micro weld,tear,begin to leak and then flame cut. With the soft and simple metal alloys of the 30's and 40's designs then yes lead does help. However automotive engines now operate far cleaner with less fouling and go 200,000+ miles before a valve job. In the leaded gas days a valve job at 75,000 miles was no surprise. Your lightly stressed water cooled tractor does not require lead or any lead snake oil substitutes. If an engine does not suffer from detonation with 87 octane gasoline, running it on 94 octane WILL NOT add power or efficiency. All high octane gas is about is it just requires a higher ignition temperature to ignite. There is the same or less energy in a pound of 94 octane fuel than in a pound of 87 octane. High octane does not "burn" cleaner. The light ends in fuel will evaporate away in hours not days if fuel isn't properly stored. In the shade with a pressure cap is a must. Winter gasoline has more light ends that evaporate into vapour at lower temperatures. Required for easier winter starting as vapour burns but liquid fuel does not.
