630 3 point hitch parts
Jon
09-07-2003 14:57:40
i have just purchased a JD 630 it has the center link plate and the pieces that mounts on the rock shaft. i need all the lower pieces like the sway blocks and all the lifting arms and the lower mounting brackets. i also want to to know what elephant ears are and if i need tham also
thanks for the info
Jon
JDVan
09-07-2003 23:21:06
 Re: 630 3 point hitch parts in reply to Jon , 09-07-2003 14:57:40
If you have the top Link Yoke currently in the tractor then you can purchase the rest of the parts from private parties or salvage yards. It will be expensive. $800 to $1000 for the hitch parts including elephant ears and sway blocks and around $300 for a complete top link.
MIKE HANLEY
09-07-2003 18:27:27
In so many words,,,you don't have anything. Eather that tractor never had a 3PT from the Factory, or someone somewhere a long the line stripped the whole thing off. The castings on the rockshaft are also used to lift a front mount cultivator and are on all tractors with a rockshaft.. If the 630 ever had a 2 row mounted picker on it all the 3PT parts have to come off to mount the picker. Many Auctions they strip off wide fronts, 3PT's, weights, remote cylinders and any thing else that can be removed and sell that stuff seperate from the tractor. You have two ways to go. Find a COMPLETE JD 3PT with the EARS as that is where the lower arms mount on a factory 3 PT, or go to an after market 3PT. There are differant EARS for differant tractors and they will not interchange. If you find a factory 3PT, be sitting down when you here the price!!!!!
