730 transmission
Pat
09-07-2003 10:32:08
I have a 730 gas with a question on the transmission. The left side of the quadrant, 1st,2nd,rev, and 4th gears are quite when under a load or not. the high side, 3rd, 5th and 6th growl some and gets louder when under a load. I want to fix this and was wondering if anyone knew what to look for and the best way to approach fixing this. thanks Pat
Clooney
09-07-2003 17:22:49
 Re: 730 transmission in reply to Pat, 09-07-2003 10:32:08
Pat, those 2-cylinder Deere transmission noises sometimes travel from different areas than you would think. You might even have a 1st reduction gear mesh noise that only acts noisy in the higher gears.
~My best guess on your 3rd, 5th and 6th gear noise would be the counter shaft idler gear inner bearings, or the idler gear has flat spots worn in it's inner bore from running on worn bearings. OR, the counter shaft end bearings are worn.
~About all you can do is pull the trans apart & look at the shafts & bearings & hope that whatever is causing the noise is bad enough to see or measure. Unfortunately that counter shaft idler gear is about the last thing that comes out....
