DEERE 4430 1st 2nd GEAR -QUAD
MB
09-07-2003 08:02:41
I hsve a 4430 S/N 20606 in which the 1st and 2nd gears do not pull in the quad speed. 3 & 4 & reverse are good. It was shifted without the clutch when the clutch was going bad. Engine lugs slightly but no movement. I am wanting to sell but I am afraid of the repair bill putting it out of sight. 7800 hours.
Bad Synchronizers affect either 1 & 3 or else 2 and 4. Any thoughts?
CK in SD
09-08-2003 06:12:41
 Re: DEERE 4430 1st 2nd GEAR -QUAD in reply to MB, 09-07-2003 08:02:41
I had mine gone thru at local JD shop last year for similar problem. They estimated $3500. By the time I was done, had $6000 bill, but had other problems once they got it split, so I think the $3500 would have fixed top shaft problems.
chris
09-07-2003 21:17:25
Sounds like your low side sycronizer has problems, so you need to repair the topshaft as mentioned. Splitting the tractor between the trans. and the clutch housing and removing the rockshaft housing is required. I did my cousins 4430 for less than 2 grand if I remember right and parts were 75% of the bill. All the sycro's are on the topshaft. Though once you get in there the lowershaft may need some work and that requires removing the axle housing and pulling the differential.
david val
09-07-2003 15:31:56
you probably need to rebuild the transmission input shaft (upper shaft) and if the clutch was not repaired, that's too.
david
Lloyd
09-07-2003 12:43:25
Sounds to me like something locked on that shaft. First and second are the same gear and the speed difference comes from the two-speed clutch pack. Third and fourth are on a different shaft. Quad range is basically the eight speed synco-range with the two speed doubling the gears. On my oldest 4430 the synconizers are worn out and the gears clash when shifting between ranges or to reverse but once in gear it works fine. I am no expert but maybe someone can tell you more.
