720 Clutch
720Deere
09-06-2003 16:46:11
The clutch on my 720 is very difficult to disengage. If I back the adjustment nuts off one notch the engage/disengage is "soft", but the clutch will slip under heavy load.
Could this be caused by improper pulley brake adjustment? Any thoughts on this would be appreciated.
CJDave
09-06-2003 22:46:43
 Re: 720 Clutch in reply to 720Deere, 09-06-2003 16:46:11
We recently adjusted the clutch on our 1952 "
A" and for the first time it acts like it is supposed to. What we were doing wrong was trying to adjust with the clutch disengaged. Once I read up on "how to", I snapped the clutch in and then I used a small inch-pounds torque wrench to get the bolts perfectly even at about 30 inch-pounds on each bolt. It made a HUGE difference in the way the clutch holds, AND when I snap it out, the tractor stops much better.
