730D fuel update
MIKE HANLEY
09-06-2003 06:33:50
Just got a phone call. Back ground.....730D with new engine only putting out 40 HP on thr dino. Primery pump putting out 18 PSI max at fast idel and dropping to almost zero at slow idel. Had the pump machined. Hole where the piston sets for the pressure relife valve ball wore out. Drilled out and bushed back plus machined the faces. Now puts out 40PSI at all speeds. Still only 40 HP. Sent out the rack. Even thought it was just redone, it was way off and had to be done again. Still only 40 HP. Sent out the injectors. Just like the rack, even thought they were just redone, they are a mess! Bottom line is the Diesel shop that did the work, eather didn't do the work in the first place or did a very poor job. An indepentant diesel shop in a near by city did the work the first time. This time the rack and injectors were sent out to the JD dealer at Turtel Lake Wisconsin. Injectors will be back next week and will let you know.
DON
09-06-2003 11:45:54
 Re: 730D fuel update in reply to MIKE HANLEY, 09-06-2003 06:33:50
THE PUMPS AND NOZZLES MUST BE CALIBRATED TO EACH OTHER OR YOU WILL HAVE PROBLEMS LIKE YOU DESCRIBE. ANY DIESEL SHOP FAMILURE WITH THESE PUMPS WILL KNOW.
MikeM
09-07-2003 05:15:57
 Re: Re: 730D fuel update in reply to DON, 09-06-2003 11:45:54
This is also what my shops told me. They label each inj. to each pump #1 to #1 and #2 to #2. It is hard to find good shops as my first time I sent some out the shop sent them to another place
cause they didn't do these.Lucky I asked for an estimate first as they said the pumps were completly shot needed new parts custom made cost
around $800 or $1000 can't remember for sure this was in 1985. Well I pretty much figured I was getting hosed cause the tractor ran fine I just tore it down to fix other problems and wanted these checked while down.Got them sent back all in pieces I found an oldtimer who fixed them up for maybe $300-$400 and they worked great.Bad thing is this guy retired not long after this someone bought all his parts and equip. but didn't
get his knowledge what a shame. Hope you find your missing horses.
