70 D speed hour meter
Dan
09-06-2003 05:11:05
I am in the process of restoring my 70D. The speed hour meter does not work. Is there any hope of getting it to work or should I be looking for one that does. I know the meter is no longer available but the cable still is available from John Deere.
720Deere
09-06-2003 16:41:38
 Re: 70 D speed hour meter in reply to Dan, 09-06-2003 05:11:05
I would definitely check the cable first as discussed in previous posts. Anybody that works on speedometers or instruments can overhaul one of these tachs for you. My neighbor does such work and overhauled mine on a 720D.
The cause of failure is usually bearing siezure. These tachs were meant to be greased periocally and they were definitely not built for much outdoor exposure i.e. rain and snow.
The bearings and most other parts are available thru stewart warner and others. If the face still seems to be in good shape, I would spend the $60 to $70 for an overhaul and keep it original.
F-I-T
09-06-2003 17:15:16
 Re: Re: 70 D speed hour meter in reply to 720Deere, 09-06-2003 16:41:38
720Deere:
Would you be able to provide the name of the individual that repairs these tachs ? The question comes up here often, but almost always the repair of an old tach exceeds the price of a new unit. I have several old tachs that could probably be saved, but could never find anyone to work on them.
E-mail me you would rather contact me that way.
I'm sure others here would appreciate the contact !
Frank-in-Tallahassee
[email protected]
720Deere
09-07-2003 16:43:19
 Re: Re: Re: 70 D speed hour meter in reply to F-I-T, 09-06-2003 17:15:16
I talked to my neighbor about the tachs today. He says on average it would run between $85 to $100 (usually it would be $85 unless it needs parts that he has to fabricate). He would be glad to help anyone in need of tach overhaul. I guess the best procedure would be to email me @ "[email protected]". Send me your information and I will give you the shipping address. We are located in Maryland, that should help you figure what the shipping would cost.
Sorry that I can't give you his direct information, but he is an older gentleman that is slightly eccentric. He would prefer not to "have the hassle of dealing with out of town folk". He is quite good with any type of instrument, and since he is directly across the street, it is no problem for me to handle the shipping and processing for him.
F-I-T
09-06-2003 05:50:52
Dan:
While the original AF2066R tachometer is no longer available, there ia replacement available from Deere. It is P/N AR21664, and JDParts.com shows it priced around $175.00. I installed one on my 70D and it looks and works well.
70D // 855 // VAC
MIKE HANLEY
09-06-2003 05:37:01
Make sure that problem is th hour meter. Hook a drill on to the end of the cable and watch the face. More then once we have had the cables off and then didn't get the cable set back in just right so the meter wouldn't work till we reseated the cable. Once we twised off just enought of the end of the cable at the tractor end, that it looked good at first glance. but when we went the other way and removed the cable from the meter and put the other end into the tractor and started the tractor, the cable would not turn.
