1978 jd 7700 combine alternator
carl
09-05-2003 21:22:44
Anyone have a wiring diagram for alternator w/internal regulator?
chris
09-06-2003 20:55:02
 Re: 1978 jd 7700 combine alternator in reply to carl, 09-05-2003 21:22:44
If I remember right the alternator is a delco. And the stud on the back of the alt. is hooked to the battery stud of the starter. The two wire plug has a small wire that is to the inside/engine side of the alt. that is powered from the keyswitch and needs a diode in the wire or it will kill your battery and the outside wire is live like the stud wire. Look at any GM vehicle from 1975-87 and it will have the same alt. chris
