Hello Matt, Lots of Gas in the oil suggests that fuel is leaking past the needle-and-seat in the carb and that the fuel shutoff on the gas tank was left open (or is leaking). Not really unusual. If you left the gas turned on, then the carb is probably leaking. I usually shut off the fuel on my 1953 model 50 just to be sure. As far as a burst of water shooting out of the exhaust goes... Are you sure it was water and not gas? If gas is leaking past the needle and seat on the carb, it will run into the cylinders and eventually leak past the rings. Is it possible that water could have entered into the exhaust pipe? How much water are we talking about here? It's normal for it to spit water when the engine is cold and it's first cranked up (at least my 50 does). The cylinder pressure sounds a little low. I think I get around 110 or 120 per cylinder on my 50. Really high pressure suggests that there is a lot of carbon or else water/gas is flooding the cylinder. If it were my 60, I'd first change the oil and then make sure the fuel cutoff on the tank is working. Then I'd run it a bit. If you continue to get considerable water in the exhaust then I'd be thinking that the head gasket is leaking... Best of luck, John
