630 carb question
Jeff
09-04-2003 19:52:28
We have the carb off of our 630 and the threads on the brass piece that sticks out of the bottom are stipped about halfway up as are the threads on the hole. Does anyone know what size tap to use to chase them? The brass piece mikes .400 on the threads which would make it about 10mm butI didn't think they used metric on JD's back then.
thanks!
ChuckW
09-04-2003 20:06:36
 Re: 630 carb question in reply to Jeff, 09-04-2003 19:52:28
sounds like you're referring to the altitude compensator valve. I haven't found any taps or dies that match these. I tell you why they are stripped, generally people try to remove them and the rubber o ring hold it in position and people keep backing it off, thus wearing down the threads. The proper way to remove is to get use small vice grips or pliers and lightly pull as you back the adjustment out. I believe you could buy a new one about $30 from deere and it should work. Chase the threads with it before you put the o ring on.
