70 gas gas tank baffle??
Earl S
09-04-2003 17:17:44
Two of my friends that own 70 gas have found the baffle in the gas tank laying in the bottom of their fuel tank. Do you have any suggestion how to remove it. I thought maybe we could split a rod and slip over the edge of baffle and roll it up. pull it out the fill cap. The one tractor it was restricting the fuel to the sediment bowl of which it maybe wouldn't if everything was clean. We thought about tying it off with a piece of wire the fill hole is up front.Maybe put a standpipe on the sediment bowl drill some holes in the side of standpipe. Earl
Leon
09-04-2003 20:30:03
 Re: 70 gas gas tank baffle?? in reply to Earl S , 09-04-2003 17:17:44
Earl, I had the same problem on my 70 gas. The baffle is flat on one side and has short flanges on the other. If it is laying flat side down, it cuts off the fuel. I managed to snag mine with a wire and flip it over so the flanges are down. That holds the plate up so fuel can get under it. This is NOT the fix you want to use if you're going to use the tractor a lot. I would guess the corners of the flanges could wear holes in the tank. Shouldn't be a problem with a "parader" though.
Tyler-MO
09-04-2003 18:01:37
I have seen the same problem in a 730 gas that I once owned. I thought about splitting the tank on the seam but many advised me not to as it would be difficult to seal it again. I ended up using a piece of brakeline and making a standpipe. It worked out just fine. Good luck Tyler
