1951 John Deere B Question
Brian
09-04-2003 14:26:29
I am new to antique tractors. I bought a 1951 B from an estate auction 7 months ago, I gather from this discussion board that my tractor should have a Wico mag. However, it has a delco distributor and a Behlen power steering system (part of which is connected to the delco distributor). I do not want to change anything because it starts so easily and runs excellent. Yet, I would like to know how this distributor came to be on my tractor.
PatM
09-05-2003 18:30:33
 Re: 1951 John Deere B Question in reply to Brian, 09-04-2003 14:26:29
Your 1951 B should have a distributor as they were standard equipment from the factory starting in 1950 with Model B serial number 268820.
dw
09-04-2003 17:17:50
My I&T service manual indicates a battery ignition was adopted as standard equipment in June 1950. It shows a Wico distributor being used on the B JD and a Delco Remy Distributor being used on the A JD. It is my understanding the Delco Remy is far superior to the Wico Distributor. I went from a Wico mag to a Delco Remy distributor on my '48 B and am really pleased with the Delco distributor. Would not want to go back to the mag.
Clooney
09-04-2003 15:47:14
Brian, that Delco distributor is a replacement as it wasn't used on the "B" from the factory. Over the years a lot of letter series Deere 2-cylinders have been converted to the Delco distributor. That Delco dist. is a good quality distributor & shouldn't give you any problems.
popper dick
09-04-2003 15:29:22
Brian,
I have 1950 JD B ser.# 270346 and mine came with a Delco distributer. I am the second owner. As a kid my dad had a 1950 JD B with a wico mag so I guess they made them both ways.
Enjoy you tractor.
Dick
jdman(MO)
09-04-2003 14:51:44
The John Deere Parts books lists the Delco Distributor as a suitable sub for the Wico Mag. Its your tractor I would leave it like it is. Russ
