JD 430W Fuel/Ignition Problems
Ellis
09-04-2003 11:38:53
All of a sudden we ran into some problems with our 430W. Starts okay but will miss on acceleration and backfires on deacceleration. If the tractor is put under load it misses and backfires with little to no black smoke. I have replaced the plugs with new autolites and swapped distributor caps and wires with our other good running 430U. The problem is still there. Tonight I will take a look at the carb to see if the is a restriction at the nozzle or load needle. I realize that there are many possiblities but hope it's something relatively simple. Any help or advice with expertise or experiences would be appreciated. Thanks
SteveG
09-04-2003 20:05:13
 Re: JD 430W Fuel/Ignition Problems in reply to Ellis, 09-04-2003 11:38:53
I agree with what Ray H said. Try replacing the coil with a known good one.
JB
09-04-2003 19:51:10
Hi, if you can't find any problems with fuel or ignition systems then you may want to check the tappet rocker shaft. Many years ago we had a 420U and it started misfiring/backfiring could not find any fuel/ignition problem, took off valve cover and notice the tappet rocker shaft was cracked at the mounting bolt hole and the valves for that cylinder were not being opened properly.
Good luck
JB
RAY H
09-04-2003 19:36:57
DID YOU CHANGE YOUR POINTS AND CONDENSER. THEY ARE A MAJOR FACTOR IN THE PERFORMANCE OF ANY 2 CYLINDER TRACTOR. THE PROBLEM COULD GO AS FAR AS YOUR COIL TOO. MISSING COULD BE A FUEL PROBLEM, BUT BACK FIRING SOUNDS MORE LIKE IGNITION. MAKE SURE YOUR WIRING IS GOOD TO THE COIL AND TO THE DISTRIBUTOR. MY 430W HAD TO HAVE NEW IGNITION CIRCUIT WIRING AND THAT ENDED THE CUT-OUTS OR NO STARTS. YOU DIDN'T MENTION IF YOU STILL HAVE A 6 VOLT SYSTEM. I'M NOT FOND OF 12 VOLT CONVERSIONS, I THINK THEY CREATE MORE PROBLEMS.
CPeter
09-04-2003 14:25:00
This sounds like it is a fuel delivery problem. Take the plug out of the bottom of the carb and make sure that you have a good steady stream of gas for at 1east 30 seconds. If not, check at the filter on the bottom of the gas tank. If not, there may be something in the inlet inside the tank. I had this probelm and by GENTLY blowing compressed air into the filter outlet, blew whatever it was out. the bowl assembly is supposed to extend up into the tank above the bottom to prevent stuff in the bottom from doing this, but it does happen. Start at the carb and work backwards until you find it. If it will start, it probably is not the ignition. They usually give the most trouble starting as that is when the system voltage is lowest due to starter motor load.
CPeter
Wayne in Tn,
09-05-2003 13:05:34
 Re: Re: JD 430W Fuel/Ignition Problems in reply to CPeter, 09-04-2003 14:25:00
I would try opening up the load needle some first.
