Air Filter, 1929D - Help!
Dick W
09-04-2003 11:29:56
Is there a good way to clean an old air filter for a 1929 model D or are there paper filters available? I've tried soaking it in gasoline and blowing it out but it doesn't seem to help. I'm sure some of you have run into this before and can help me out on this.
Lloyd
09-06-2003 10:35:52
 Re: Air Filter, 1929D - Help! in reply to Dick W, 09-04-2003 11:29:56
The old filter in my 26D was disintergrated and had to be dug out. I carried the can to NAPA and tried filters till we found one that would fit the hole and could be pressed snug over the intake hole when the cover was put on. The tractor does'nt work in the dust so it should be fine. I can get the filter number if you want me to. I think the filter cans are the same. Lloyd
DickW
09-06-2003 15:56:32
 Re: Re: Air Filter, 1929D - Help! in reply to Lloyd, 09-06-2003 10:35:52
I'd really appreciate it if you could post the filter number.
Lloyd
09-07-2003 12:23:39
 Re: Re: Re: Air Filter, 1929D - Help! in reply to DickW, 09-06-2003 15:56:32
Dick, The number is not real clear. It looks like 2370 and I assume that is a NAPA number. I will call NAPA tomorrow and check on it. It fits real good in the can and I cut a round piece of rubber to seal the outside end when the cap is replaced. Does your tractor have the brass carburator? I can't get mine to run good and I think it is the carburator. Its been sugested I replace it with a later version. I would like to talk to you some about your tractor. You can e-mail me at [email protected]. Lloyd
Patrick McDougal
09-10-2003 21:38:07
 Re: Re: Re: Re: Air Filter, 1929D - Help! in reply to Lloyd, 09-07-2003 12:23:39
K&K tractor has replacement elements for early D and GP.Cost about 40 bucks.They use filter material from furnace filters,works good.
Glen in TX
09-04-2003 12:33:36
Kerosene works well to flush out the old hair air filters and leaves a oily film then to trap dirt. Just put some in a can or bucket and give it a bath in it. It was recommended over gasoline or solvent for years to clean oil bath filters too. You can also just use dishwashing soap and water. Be careful of the harsh degreasers out there as they can dissolve the hair in the filter. I think someone is making those filters or has a replacement.
