1973 JD 110 Variator troubles and how to get at th
Chuck McDonald
09-04-2003 11:27:32
Hey gang,
I bought a 8 h.p., 4spd, 1973 110 JD not too long ago and i have some questions
1. When mowing or driving and already moving with the clutch relaeased I will have the variator lever pulled to the rear. I begin to move it forward and the mower will SLOWLY pick up the speed (acts like weak spring pressure). AT times also it will be about midway and the tractor will start up a little hill and then stop moving. If the lever is moved forward slightly more it takes off like a shot! How do you adjust it? In addition, if the clutch is pushed down quickly sometimes it sounds as if a pully is rubbing the underside of the floor. What could that be? Does anyone have a copy of the manual talking about its adjustment they could email me or send me? 2.) how hard is it to take off the fenders/floorboard (one piece) on this tractor. Are the peddles hard to get off?
3.) what wieight of oil is used in the transaxle and how much to fill it? Also, what about the motor, oil weight and ammount.
Thanks a bunch guys. You will make a poor college students day!
Chuck McDonald
Mark Anderson
09-05-2003 12:04:26
 Re: 1973 JD 110 Variator troubles and how to get a in reply to Chuck McDonald, 09-04-2003 11:27:32
Set your control lever in the fifth notch when the tractor is running, and then loosen the bolt that takes a 3/4" socket and allow the clutch pedal to come all the way up. Then tighten the bolt again. Make sure that the spring from the variator to the small link from the transaxle isn't broken. I have also sprayed wd40 up into the variator when running to loosen it up again. Mark..
F-I-T
09-05-2003 12:09:12
 Re: Re: 1973 JD 110 Variator troubles and how to g in reply to Mark Anderson , 09-05-2003 12:04:26
I thought I remember that you pull the coil wire, hold downward pressure on the cap bolt and crank the engine a few times (may need a helper) and that will bring the pedal up. It was that way on my old 214.
Frank
Duane Klinger
09-04-2003 21:03:58
Chuck, It just so happens that I to have a 1973 110.Ours was bought new by my grandfather.Now for your problem,it sounds to me like your two belts that drive your tractor are wearing out or your bearing in your variator is starting to lock up.Either way you are about to get introduced to the wonderful world of John Deere engineering.Having said that you really need to go to your local John Deere dealer and get a tech book specific to the serial number on your tractor.It will give you all the info you could ask for and then some.If that is not a good choice for you,you can email me at the above address and I will try and talk you through it.
Chuck McDonald
09-05-2003 06:38:40
 Re: Re: 1973 JD 110 Variator troubles and how to g in reply to Duane Klinger, 09-04-2003 21:03:58
Hey Duane,
you have your email hidden so i cant email you. I would like some basics on the adjustment though. I am somewhat sure the belts are no good as i have already replaced the mower drive belt and the pto belt. Also, they dont look really good the small ammout i have seen of them. If you could just give me a quick and dirty lesson on adjusting it that will do. Thanks a bunch!
chuck
phil
09-05-2003 10:54:47
 Re: Re: Re: 1973 JD 110 Variator troubles and how in reply to Chuck McDonald, 09-05-2003 06:38:40
Chuck, on my 1969 8HP 110, I have replaced the mower drive belt & the pto belt maybe 8 or 10 times each. But the original variator belts were still doing their job in 2001 when I sold it. Yours might be no good, as you say, but it's not for sure. The adjustment is on the right side under a little cap, near the bottom of the gas tank. Some of those clutch noises will go away when you adjust the variator lever (the adjustment will put the spring under more tension, & it will reposition the pulley-pair when the clutch petal is down).
