Help! 1010 steering backwards!
Fence
09-04-2003 09:17:30
A lady here in East Texas is selling her JD 1010 for $1000. It is in pretty good condition with no serious dents (needs paint), etc. But, her husband changed out a bad steering pinion gear(?) and now the tractor turns right when you turn the steering wheel to the left, and left when you turn it to the right?? Is this something that I can fix by changing out the gear or could he have installed it backwards? This is really weird.
Thanks in advance.
Fence
Clooney
09-05-2003 03:18:42
 Re: Help! 1010 steering backwards! in reply to Fence, 09-04-2003 09:17:30
Fence, I have my doubts that an incorrect pinion gear could change the steering direction. The gears would still have to fit in about the same location & therefore the shafts would still be on the same side of the gears so it couldn't turn backwards.
~Even the hydraulics hooked up backwards would have a hard time turning it backwards as the steering wheel would have to be turned one direction to activate the hydraulics & if the hydraulics then turned the front wheels the other direction the steering wheel would have to follow in that direction. ~About the only thing I can think of is someone installed the outer steering arms facing the wrong direction or the center steering linkage is installed facing the wrong direction. I have seen the steering linkage installed wrong a few tractors over the years but can't recall ever seeing a 1010 set up backwards.
G-MAN
09-05-2003 11:06:13
 Re: Re: Help! 1010 steering backwards! in reply to Clooney , 09-05-2003 03:18:42
Clooney, is the 1010 steering system fully hydrostatic of just a power-assist system? From what I can tell from EPC, it looks to be fully hydrostatic, with no mechanical connection from the wheel to a steering gear, but that's just what I can tell from parts pics.
Dan
09-04-2003 21:02:17
As mentioned below, probably the wrong worm gear. I replaced one on a 430 one time and had to buy the whole steering box. Never checked it when first put together but first time I went to use it it steered backwards. I think different models have the tie rods on different sides of the axle. I think the 1010 is probably pretty similar to the 430in steering.
Ray
09-04-2003 18:20:49
There are left and right steering boxes from
different tractors.I tried to change one from
a 430W to a 430S it did the same thing.(The worm
gears are different,left and right thread)
Fence
09-05-2003 07:28:05
 Re: Re: Help! 1010 steering backwards! in reply to Ray, 09-04-2003 18:20:49
Ray - it is the wrong worm gear! You were right. Can I just buy the gear and not the whole box assembly? Do most JD dealers stock parts for this tractor, or is it best to post here on the board and locate the part?
G-MAN
09-04-2003 10:56:45
I'm not too familiar with the 1010, but I'd say it's probably something relatively simple, such as the lines leading from the metering unit or to the steering piston being turned around. All I have is a parts picture to look at, but the metering unit (what the wheel is attached to), looks to be fairly common, and possibly has four lines leading to it - one for supply oil, one for return oil, and the other two going to the piston. If those two are hooked up backwards, I would imagine it's going to turn the right way. Should be an easy fix, but you might want to have a manual handy, just in case.
Fence
09-04-2003 13:10:01
 Re: Re: Help! 1010 steering backwards! in reply to G-MAN, 09-04-2003 10:56:45
I talked with the lady and she said that she believed that her husband had ordered and installed the wrong worm gear. Does that sound possible?
Fence
G-MAN
09-04-2003 16:03:00
 Re: Re: Re: Help! 1010 steering backwards! in reply to Fence, 09-04-2003 13:10:01
That's probably possible, Fence. I was going on the assumption that it was a power-steering equipped tractor, and not manual steering. There are a few different steering gears listed for the 1010, depending on what model it is, all of which are no longer available. Perhaps he got a used set from somewhere. If the tractor has manual steering, that's just about got to be the problem, but like I said, I'm not too familiar with the 1010. Maybe she can find some sort of paperwork on the parts he bought and determine the part number so you can compare it to what the tractor actually should have.
