70 vs. 620
Tye
09-04-2003 08:09:38
If I wanted to buy a 50hp tractor of the 2 cylinder variety, when comparing the overall weight, engine,transmission, toughness of transmission, clutch etc. excluding the fact that the 620 has better hydraulics, which tractor is going to give a better bang for the buck? Thanks for any responses.
Doug in IL,
09-04-2003 18:44:57
 Re: 70 vs. 620 in reply to Tye, 09-04-2003 08:09:38
The 70 is far and away the toughest of the two. I've owned four 70's and one 620 over the years. I still have a 70. The 3 point is better on the 620. However, is is lighter in the front, requiring a lot more weight on the front to lift what a 70 will. I do not like the foot pedal pto activation on the 620 either. A 620 will NOT pull near what a 70 will. If you operate both of them, I think you will find the 70 to be a much more substantial machine.
Clooney
09-04-2003 15:55:17
Tye, having owned both of the mentioned tractors I would have to say go with the 620. The 70 has rather poor gear ratios & a very fast 1st & reverse. The 70 is also a gas hog. I does make a good plow tractor but looses a lot in the utility tractor category.
~The 620 has a good creeper gear, better hydraulics, better fuel economy, & makes a much better all around utility tractor.
buickanddeere
09-04-2003 11:23:53
620. Similar HP, slower 1st gear and reverse, better three point hitch, better fuel efficiency. The fuel record probably still stands.
John T
09-04-2003 08:17:16
Hi again Tye, Ive owned a few of each, recently sold my last 70 and got a 620, and the answer depends a lot on if you need and how you would use a 3 pt hitch. If you really need a good 3 pt, (not just raise and lower light duty equipment like a 70 add on 3 pt would do) then the 620 has to be the answer. However, a 620 with a complete factory 3 pt is gonna be a lot more bucks. If you just use pull type equipment mostly, then I would go with a 70.
Best wishes n God Bless
John T Nordhoff
mike-nm
09-04-2003 10:02:52
 Re: Re: 70 vs. 620 in reply to John T, 09-04-2003 08:17:16
Hey john T- how much weight will a 630 pick up? or a 730? I mean the 3 point that is. just wondering-- Thanks
JDGnut
09-04-2003 14:31:06
 Re: Re: Re: 70 vs. 620 in reply to mike-nm, 09-04-2003 10:02:52
If I was tractor pulling I would go with the 70.. a little more potential.. for working.. I would have to go with the 620.. (even better a 630) the hitch is the biggest difference.. Stock... the 620 will hang close to the 70 in Hp...
Now a 70D.. That's a different story.... JDGnut
