720 starting problems
Graber in SD
09-03-2003 20:55:40
My 720 will not fire unless I turn the switch on and off about 5 times while I am cranking it.This is a new switch. I had to do the same thing with the old switch. Any ideas?
Graber
09-04-2003 13:16:47
 Re: 720 starting problems in reply to Graber in SD, 09-03-2003 20:55:40
It seems as corrosion aroud the ammeter leads caused the whole problem. Thanks for your responses. Next time I have an electrical problem I will check out the connections first. I forget that some of these connections haven't been touched for 50 years!
John T (Troubleshooting)
09-04-2003 07:02:08
Good Morning Graber, First, is the tractor equipped with an external ballast resistor, and if so, does it have a working startign by pass circuit???
What that circuit does is to by pass the ballast and supply full battery voltage to the coil ONLY when the engine is cranking afterwhich coil voltage is reduced to that remaining AFTER the drop across the ballast. The coil is a 6 volt so the ballast drops the 12 batetry volts to 6 so the coil dont overheat and the points do not over current causing premature burn out.
If it has the ballast and by pass circuit, from your description I wonder if its working, because if so she would fire when cranking REGARDLESS IF THE SWITCH WERE BAD!!!!! !!!!! Therefore, for now at least, Im suspectign more of a load side ignition circuit problem.
Since the switch is new and the old one acted the same, its quite possible the problem lies elsewhere, like a bad connection somewhere in the ignition circuit. Heres how I would proceed:
1) Remove each and every connection in the ignition circuit, clean and scrape and wire brush the terminals and connectors, and then re attach them all. This would include the switch terminals (supply and load sides) the coil (+ and -) and ballast and distributor terminal (wire form coil).
2) Remove and clean and brush the wires from the load side of the ammeter or L terminal on the Voltage Regulator (if it has one).
3) To be safe, you may as well remove the distributor cap and remove and clean and re attach the wires to the ignition points and also the side terminal where the wire form coil atatches if I missed that above.
4) Inspect ALL wire end terminals to be sure none are loose or carboned and if any are suspicious, replace them. Althoyugh many used crimp on connectors, its a better conenction if they are soldered on. A bad terminal end can cause a problem. Re Squeeze them down if they are crimp on types and insure no looseness or carbon.
THE ABOVE SHOULD FIX THE PROBLEM IF ITS A BA CIRCUIT OR CONNECTION OR TERMINAL. IF NOT, SEE BELOW:
5) To make sure if its a circuit problem as above, try runnign a hot wire direct from the ungrounded battery post to the coils high (not to distributor) terminal and see how she fires with that hot wire atatched????? ????
6) If she starts n runs fine hot wired, but not via the switch, the coil and points are good so your problem must be in a connection or wire or the switch or the circuit feedign the switch.
7) If she acts the same hot wired, then the problem is in the coil or points circuit which are all downstream from the coils high input (not to distributor ) side so take a look at the points and condensor and lil side distributor terminal (where coil wire feeds through). It has to be internally insulated from the distributor case where it passes through the hole.
8) Are the points clean, not gray oxide coated and not burned or pitted or carbioned up????? ????? ?? If so, replace them and see what happens. If they are intermittent or carboned that can change thigns once they are warmed up a bit or you keep flashign the circuit on and off like turnign the switch on and off.
Try this then post back or e mail me [email protected] or call me at (812) 824-4608. However, Im gonna be at a tractor show (Elnora Indiana) a lot the next few days and may not be able to respond.
Good luck n God Bless
John T Nordhoff in Indiana
Graber
09-04-2003 05:20:01
Thanks for the step by step instructions.I am going to try to get to the bottom of this problem.
Clooney
09-04-2003 03:57:31
Graber, that is a strange occurrence.
~The first thing that comes to mind is your by-pass starting wire from the starter to the distributor side of the ballast resistor has failed or has an open. That or the starter switch on the starter isn't supplying power to the distributor side of the ballast resistor during cranking.
~The first thing to try is cranking the tractor WITHOUT turning the ignition switch on. Then as it is cranking turn the switch on. If it starts easier that way suspect a problem with the by-pass starting�.You can use a voltmeter on the ignition switch side terminal of the coil & see if you have at least 10+ volts during cranking, if not again suspect a by-pass circuit problem.
~If your voltmeter on the coil�s ignition switch side shows a drop in voltage as the switch it turned to different places suspect a problem with the coil�s shorting circuit. The ignition switch has a shorting terminal [mag terminal] to short the coil to ground when the ignition switch is turned off so the engine won�t fire when the starter is cranked with the ignition switch turned to the off position.
~If none of the above helps or you still aren�t sure if your by-pass or shorting circuit are the problem just remove both wires from the ignition switch side of the coil then run a power jumper wire directly from the battery�s NON GROUNDED SIDE post to the coil�s ignition switch side. If it starts better then suspect a by-pass, shorting circuit, or ign switch resistance problem. If it still starts hard suspect a coil [maybe you are using an internally resisted ignition coil & that won�t work worth a hoot with a ballast resistor system]. Or possibly you have carb choke problem & by turning the ign switch off you are allowing fuel to build in the cylinders without firing.
~As another test, take 2 old [or new] known GOOD spark plugs, then open the plug gap to 3/16�, then install those plugs in the plug wires [leave the old plugs in the engine for cranking pressure] , then lay those plugs on the engine block, then crank the engine�You need to see a bluish spark jump those 3/16� plug gaps MULTIPLE times in a row while cranking. If you don�t refer to the above for possible problem areas.
[email protected]
