2 Cyl diesel question
Bill R
09-03-2003 20:26:04
new to 2 cyl diesels but learning fast! On my model R there seems to be a bit of fuel coming out of what appears to be a weep hole on the bottom of the fuel pump that pumps the fuel through the filters, I put in new seals on the drive shaft for this pump a few months ago. What Can i do to stop that leak, or why is it leaking? thanks for any responses i don't post much on this board but do read alot.
F-I-T
09-04-2003 06:09:10
 Re: 2 Cyl diesel question in reply to Bill R, 09-03-2003 20:26:04
third party image
Bill R:
Two things might be the problem. First, if your new seals are resting on a worn spot on the shaft, it could still leak. That weep hole is between the seals to prevent a leaky seal from passing fuel into the crankcase. Seals are cheap, and you might weant to try it again.
Another thing that might be a problem, though I think it's a stretch, is that the by-pass ball and spring might be jammed shut, allowing the pump to build excess pressure. That might push fuel past the seals, too. You might want to start by checking that the ball is rust free and able to move correctly.
Frank-in-Tallahassee
70D // 855 // VAC
Bill R
09-04-2003 12:43:30
 Re: Re: 2 Cyl diesel question in reply to F-I-T, 09-04-2003 06:09:10
thanks F-I-T, but I don't think its rust, the fuel system appeared very clean when the pump was apart, thanks for the info, I'll probably try some new seals, also, is it normal for the sediment bowl to run about 1/4 inch down at the top, (not quite full)? thanks
F-I-T
09-04-2003 13:13:56
 Re: Re: Re: 2 Cyl diesel question in reply to Bill R, 09-04-2003 12:43:30
>>Is it normal for the sediment bowl to run about 1/4 inch down at the top, (not quite full)?
I've never seen that myself. Might be the design. Not a clue.
Frank
