3020 gas piston seized
Terry
09-03-2003 16:56:48
Maybe ya'll can help. Bought a 3020 gas that sat for a couple of years uncovered and the engine filled with water was able to get 2,3&4 loose and out but #1 is froze solid in the liner, I have soaked with Kroil and PB Blasterand it wont move , Have tried to jack it out and all I did was lift the front end off the ground, Said OK and tried to jack the liner out with same results altough the liner did come up about .005ths. Any thoughts on how I might get the piston out and or the liner I'm not trying to save the parts just trying to keep from damageing the block. Will appreciate any imput. Thanks..Terry
KennyG.
09-03-2003 19:10:00
 Re: 3020 gas piston seized in reply to Terry, 09-03-2003 16:56:48
I had a stuck piston in my 4010 that would not budge. Finally I drilled and tapped a 1/2" hole in the center of the piston and screwed a foot long piece of 1/2" threaded rod in there. I had a piece of 1 1/4" square stock with a 5/8" hole in the center and supported the ends with 2" blocks out past the sleeve, effectively making a puller. It pulled pretty hard but I got both the sleeve and piston out at the same time. Then I put the Sleeve with the piston in it over another sleeve and pounded the piston out, saving the rod. Good luck.
twopop
09-03-2003 18:30:15
first I would fill the cylinder with white vinegar,kroil or pb blaster wont eat op rust,but vinegar will.if that doesnt work,fill the block with water and heat the block to heat the water.the cylinder should expand before the piston does,keep pressure on the piston,however the rain water should not effect the sleeve,maybe you werent applying pressure at the right place.once i put a jack under the sleeve and raise the tractor up then laid a 4x4 on the top of the block and hit it with a sledge.
