2355 v.s. 2440
Grego
09-03-2003 16:56:04
I have been looking around for 50-70hp JD tractors
I am interested in any comments as to the differences between
the 2x55 and 2x40 series, and recommendations.
I will be using it to run a heavy chipper,
grader box, small field implements.
thanks in advance
Grego
09-04-2003 18:00:26
 Re: 2355 v.s. 2440 in reply to Grego, 09-03-2003 16:56:04
Hey thanks one and all for the tips!
I assume the recommendation for the overrun
clutch was because of the big flywheel in the
Chipper, right? Good point.
I have also noted that there are more 2640's
around here than 2440's. Any specific warnings
about them? -grego
Tyler-MO
09-04-2003 17:36:01
I grew up on our 2440 and I have to say it was a tough tractor. Ours was a row crop utility model with flat top fenders, 3point, straight front axle, and a 145 JD loader. We used it to do nearly everything except heavy tillage (our 4020 got that job). Baling hay, mowing hay, raking hay, digging postholes, planting, drilling wheat, loader work, and many others. It had the hi-lo option and was a breeze to use. We did have to do an engine overhaul once due to just plain old engine wear. Transmission never gave us problems but it had a noisy hydraulic system. JD informed us the due to an engineering flaw the supply pump in the rear end was not able to give sufficient volume of hydraulic fluid to the main pump in front of the engine. Other than that we never really had any problems. Oh yeah, one thing with either tractor you choose ....the fiberglass nose cone will break very easily...I would suggest that if this ever happens to fabricate a metal one like my father made. Good luck on your choice. Tyler-MO
John
09-04-2003 15:11:13
Just make sure you use a PTO over running clutchon your driveshaft. Particularly on the 2550. Otherwise you will smoke the PTO brake and cause all kinds of hydraulic funkiness.
Indydirtfarmer
09-04-2003 04:50:14
I have a 2440. It's quite a package. It is small enough to be transported easily, and powerful enough to do the job. I'm not as familiar with the 55 series. (I have a 4955) It would seem the price will be a bit lower on the 2440, due to age. But if you're like most of us, you want something worth the investment, and sometimes that means getting something more expensive. Here is what I've learned about 2440's. They are subject to electroulosis. This is an "affliction" of the cooling system, where small particles in the coolant, eat at the bottoms of the cylinder sleeves, untill one is eroded enough to allow coolant into the crankcase. Big problem. There is an easy cure. John Deere offers a kit (for the Moline tractors, but it will adapt to the 2440) that is a filter for the coolant. Change it once a year, and don't worry. it's just like an oil filter. The Hi-Low option is nice. It works great. If you have to have the tractor split (like for a clutch) you can add $2000 to the bill if it's Hi-low equipped. NEVER PULL START A HI-LOW equipped tractor. BOOM. $$$$$$$$$$$$$$$
JDknut
09-04-2003 16:50:41
 Re: Re: 2355 v.s. 2440 in reply to Indydirtfarmer, 09-04-2003 04:50:14
Indy:
I have heard a lot about electrolysis, particularly on the 40 and 30 series utilities. Were the -50 and -55's which used the 3.9 liter four prone to this, too? I am wondering if I should consider a coolant filter for my 2350. My JD dealer said that all wet sleeve engines were prone to this but did not mention any particular models. Thanks for your help.
