GP Carburetor float
RAR/IA
09-03-2003 11:51:07
Where can I obtain floats for the brass carburetor used on GP's? Tried on the sponsors lists here to no avail.
Roger in Iowa
Mark
09-03-2003 14:29:34
 Re: GP Carburetor float in reply to RAR/IA, 09-03-2003 11:51:07
I needed a float for my 29GP. I made my own. I ordered a float for an HJD,it was the correct diameter and also about the same thickness as the old float, removed the small bracket that was soldered on it, usually a good soldering gun will work, then took an old float arm from a float for an A or B, a piece of flat brass would work also, soldered it to the float and the other end to a roll pin cut to the correct length to fit the carb, I have used this for 10 years without a problem. Mark.
Clooney
09-03-2003 14:17:49
RAR/IA, Kevin @ Farm Power Restoration [610-845-3668] has [or at least had] those floats. He also has a lot of GP parts & gaskets. 9-5:30 EST M-F..
John T
09-03-2003 13:03:23
I would try Cork Groth of Cork's Tractor Trauma Center located at 24880 145th Ave., in Eldridge, Iowa 52748 (563) 285-7009 [email protected]. He and I gave seminars at the last Gathering of the Green in Moline Illinois and he was excellent regardign carbs and mags.
John T
RAR/IA
09-03-2003 13:39:38
 Re: Re: GP Carburetor float in reply to John T, 09-03-2003 13:03:23
Tried that. WAnted gears for Mag and two floats, and gaskets. Said he would not sell gears. Ordered mag complete, floats and gaskets and he backed out of all. Going to call him again and find out what is going on.
RAR/IA
NigelB
09-03-2003 14:18:51
 Re: Re: Re: GP Carburetor float in reply to RAR/IA, 09-03-2003 13:39:38
What carb are you refering to is it a ensign K by chance? nigelB
RAR/IA
09-04-2003 13:00:19
 Re: Re: Re: Re: GP Carburetor float in reply to NigelB, 09-03-2003 14:18:51
It is an Ensign.
RAR
NigelB
09-05-2003 10:45:06
 Re: Re: Re: Re: Re: GP Carburetor float in reply to RAR/IA, 09-04-2003 13:00:19
Well if its a "K" i made one out of brass because the cork ones arnt worth a dame if you want one made give me a Email! regards nigelB
RAR/IA
09-05-2003 16:33:28
 Re: Re: Re: Re: Re: Re: GP Carburetor float in reply to NigelB, 09-05-2003 10:45:06
May give you a call. We are pursuing another lead but may be back in touch. We actually need three.
Roger
NigelB
09-06-2003 01:00:51
 Re: Re: Re: Re: Re: Re: Re: GP Carburetor float in reply to RAR/IA, 09-05-2003 16:33:28
I can make as many as you want,give me a call if you get stuck.
RAR/IA
09-07-2003 12:16:25
 Re: Re: Re: Re: Re: Re: Re: Re: GP Carburetor floa in reply to NigelB, 09-06-2003 01:00:51
What is your price, each?
Roger
