How much Calcium
JD Earl
01-18-2004 20:20:38
Can anyone tell me how much calcium to put in the rear tires of my 420S?
Thanks JD Earl
BRANDON
01-25-2004 18:31:21
 Re: How much Calcium in reply to JD Earl, 01-18-2004 20:20:38
I OWN A TIRE SHOP, AND I ALWAYS PUT WATER AND ANTI FREEZE IN REAR TIRES. IT WORKS JUST FINE. AND IT WONT RUST THE RIMS EITHER.
buickanddeere
01-19-2004 07:23:41
None. External cast weights are the 1st choice and fluid #2. The previously mentioned windshild washer fluid or the beat pulp product called "rim guard" are the only two logical fluid choices now. Way back when in Grandpa's day they didn't know any better. Nothing superior was available or they didn't know/care about rotton rims. Acording to the Firestone tire engineers are 27HP tractor should weight at most 3900lbs. Exceptions for mounted equipment. Not a bad idea for drive train life in those tractors too. On occasion someone ballasts 420/430/435/440 down to a 620/630's weight. Luggs it in the lower gears and then wonders why the ring and pinion wore out.
Old Joe
01-19-2004 02:43:52
Liquid Tire Ballast
The following table represents the weight achieved by filling the tire 75% full (valve level) with water.
Use of chemical agents to prevent freezing will affect the weight.
Farm Tractor Tires (Turf tires can be found below this chart)
TIRE SIZE GALLONS OF WATER ADDED WEIGHT (lbs.) PER TIRE 4.00-12 2 17 4.00-15 2.5 21 4.00-19 3 25 5.00-15 3.5 29 5.50-16 5 42 6.00-12 4.5 37 6.00-14 5 41 6.00-16 6 50 6.50-16 7 58 7.50-10 6 50 7.5L-15 8 66 7.50-16 9 75 7.50-18 10 83 7.50-20 11 92 9.00-10 9 75 9.5L-15 11 92 9.50-20 18 150 9.50-24 20 167 10.00-16 17 142 11.00-12 18 150 11L-15 13 108 11.00-16 23 192 11L-16 15 123 14L-16.1 27 225 16.5L-16.1 42 346 7.2-24 9 75 7.50-16 9 75 8.3-24 13 108 9.5-16 12 100 9.5-24 17 142 9.5-36 25 209 9.5-42 29 242 10-16.5 12 97 11.2-24 24 200 11.2-28 27 225 11.2-34 33 275 11.2-36 35 292 11.2-38 36 300 12.4-16 21 175 12.4-24 30 250 12.4-28 35 292 12.4-36 44 367 12.4-38 46 384 12.4-42 51 425 13.6-24 38 317 13.6-26 40 334 13.6-28 43 359 13.6-38 57 475 14.9-24 47 392 14.9-26 48 400 14.9-28 53 442 14.9-30 57 475 14.9-36 64 534 14.9-38 67 559 15.5-38 66 550 16.9-24 61 509 16.9-26 65 542 16.9-28 69 575 16.9-30 73 609 16.9-34 82 684 16.9-38 90 751 17.5L-24 55 459 18.4-16.1 49 409 18.4-24 75 626 18.4-26 79 659 18.4-28 84 701 18.4-30 89 742 18.4-34 100 834 18.4-38 110 917 19.5L-24 73 609 20.8-34 128 1068 20.8-38 140 1168
Turf Tires
23x8.50-12 6 50 23x10.50-12 7 58 26x12.00-12 10 83 25x8.50-14 7 58 25x7.50-15 6 50 25x10.50-15 7 58 25x12.50-15 8 67 27x8.50-15 7 58 27x9.50-15 9 75 27x10.50-15 10 83 29x12.50-15 14 116 31x12.50-15 18 149 31x13.50-15 19 158 31x15.50-15 20 166 33x12.50-15 22 183 44x18.00-20 56 476
Dr.EVIL
01-19-2004 07:08:58
 Re: Re: How much Calcium in reply to Old Joe, 01-19-2004 02:43:52
I think what He wants to know is how much CaCl per gal. of water. Firestone's web site says either 3-1/2#/Gal. or 5 gal. depending on how cold Your area gets. But I can't remember the exact temp. the different concentrations remain "Slush-free" You for sure don't want the solution to freeze. If it was my tractor I'd use windshield washer solution since it isn't corrosive like Calcium Choride is.
