I have an early 720D standard that appears to have a broken connecting rod, I HAVE A 70D for parts, with good block, rods, pistons, crank, etc. Planning to repair the broken rod in the 720 (with rod from 70). If piston is stuck (rod broke years ago), then I would try to free it up and if pitted badly, I would plan on swapping the blocks with the one from the 70. Also, if the block is torn up from the rod, I would swap the blocks. If the crank is bent, then I have that too from the 70 that I would use. I dont want to spend much $ to do this work and/or buy any new parts if possible. Is there anything that I am missing here before I attempt to do this? Are there any parts you'd suggest I buy new when doing this work? Where can I get the valve/cylinder gaskets? Mother deere? If going this far, should I bore out the block? What does that cost? Any suggestions for a place to do it in Ohio/Indiana/Michigan you'd recommend? Would appreciate any and all of your thoughts/comments before I tackle this!!!
