730 PTO clutch question...
mike-nm
09-02-2003 22:07:46
I took my clutch apart today to see why it wouldn't work and I discovered that the hold down keepers for the triangular plate on those 3 pins were broke. My question is, where do I get those keepers? None of the parts stores around here had anything like that. All they had were e-clips and I don't think they're gonna hold and I don't know what kind of pressure is on that plate. Does anybody know where I can get keepers that are strong and does anybody know what they are called? Would John Deere have them? My local John Deere is 50 miles away.
Thankyou, I appreciate all replies...
Mr. Green
09-03-2003 03:37:08
 Re: 730 PTO clutch question... in reply to mike-nm, 09-02-2003 22:07:46
Are you talking about the 3 pins for the brake plate? It has 3 pins, and 3 retaining rings. This part number is from my 620 parts book. But i think it's the same clutch. Retaining ring (3 used) F 3396 R
I think John Deere will have them.
Clooney
09-03-2003 03:36:11
Mike, Deere still has those F-3396R retaining rings [or at least did about 6 months ago]. If you have a credit card your Deere dealer should UPS them to you. I have also had good luck using 2 small external snap rings in each pin groove. E- clips probably won�t hold so don�t use them. You need either the Deere closeable retainers or regular snap rings [2 thin ones should should fit in each groove]�
