3020 Charging problems
Mark
09-02-2003 19:48:25
I have an older 3020 with 12 volt, positive ground, with a generator. I have been toying with the idea of changing it to 12 volt, negative ground, with an alternator. I�ve read most of the articles on this web site about changing to an alternator. I guess my question is has somebody out there done this to JD. If so what are the problems.
Thanks
Mark
MICHAEL
09-04-2003 11:32:23
 Re: 3020 Charging problems in reply to Mark, 09-02-2003 19:48:25
Mark,
I've never been a wrench turner-too busy with sports and work growing up poor...Last winter I successfully changed my 3010 to an alternator. If I can do it anyone can! I used this site and the archives as wel. John T and Clooney were wonderful and patient in their advice. They are a treasure to those of us who are a bit mechanically challenged. My only problem is mounting the alternator so that it is square to the fan belt but does not touch the fan blades themselves. I ended up cutting a notch in the alternator housing to get the correct clearance. Worked great until the rotor shaft of my new alternator slide foreward a bit and began to hit the fan blades. I done a bit of grinding and shimming to get it to work. The electrical side of the equation has been fantastic. I don't have to leave the tractor tied to the charger anymore. I have power to plow, mow, and disk. While I was doing the work I changed out most of the wires as they were old and cracked. I added some better lights and changed the key ignition for a master switch and a push starter. I also added a electronic ignition module and put in new plugs. I trashed the old muffler and put on a chrome pipe. It runs like a top and sounds like a tractor too.
I had a blast doing this and the thrill of starting it up and seeing everything work is beyond words. I'd do the whole thing for you for free just for the experience. Feel free to e-mail me if I can be of any help.
Michael
[email protected]
Mark
09-06-2003 08:26:35
 Re: Re: 3020 Charging problems in reply to MICHAEL, 09-04-2003 11:32:23
Thanks for the input.
Mark
