285 PTO stopped working.
Mark C.
09-02-2003 19:05:04
Today I started mowing the lawn and after about 3 minutes the PTO disengaged as though I had gotten off the seat or turned off the PTO switch. After that it would not do a thing when I tried to turn the PTO switch back on. I didn't hear anything break and I haven't experienced anything like this before.
I tested the switch under the seat and it tests OK. I do not know how to test the PTO switch itself (I don't have a schematic). Can anyone tell me how to test it, or have any other suggestions on what to look for? The PTO shaft is definitely not spinning.
Please help! The lawn is growing and the local repair places take forever to fix these things.
Thanks!
Handsome Jim
09-03-2003 18:05:51
 Re: 285 PTO stopped working. in reply to Mark C., 09-02-2003 19:05:04
Mark,
I'm not sure what a 285 is but I think it is a larger version of my 265.
Probably the simplist way to check your PTO switch is to switch it on and then get out of your seat. If the engine starts to die, you have continuity and the switch is functional.
The PTO clutch is probably the culprit (I replaced the clutch on my 265 earlier this summer), $115.00 parts, brother inlaw did the wrenching. It's not a real complicated job but you do have to drop the deck and there is an adjustment on the clutch. good luck.HJ
