48 A water vapor
George K
09-02-2003 19:01:39
Got an "A" a month ago, don't know its history.
Appears that the engine has been rebuilt, has aftermarket rod on one side, does not smoke, uses no
oil. Disked a couple acres with it in 2nd gear, only got temp up to 140 deg.
Changed oil, got about 1 oz clear water, did Diesel fuel flush, running about 2 min, replaced oil with 10W-40, new filter. Tranny/diff was milky, drained about 1 oz water, did Diesel flush, replaced oil with GL-4 90w. Got the disk out again, this time in 3rd gear to put a load on it. Got the temp up to about 165 degrees, and noticed vapor comming out of the pully/clutch and out of the crankcase vent when I slowed down for a turn. I thought it was smoke at first, but it was water vapor.
Next day, cracked open the drains for crankcase, tranny, and differential. Got about 1 oz water from crankcase again, maybe a 1/4 oz from tranny and differential drains. Tranny oil mucky like it has water (and it did).
Where is it comming from? Was it leftover in some pockets somewhere? The reason I did a flush on crank and tranny was there was sludge in the bottom I could stick my finger in the hole and feel. Could the water be comming from leftover sludge? They felt clean after the flush, but who knows what I could not feel.
The humidity on the day was around 30%, not very high around here, but it did rain a few days ago and the field was damp.
The tractor has 50/50 anti-freeze / water in the radiator, and the water comming out of the case was clear, not green. Did not check the radiator level prior to the run, so don't know if I lost any from cooling system.
Could it just be condensation?
Any help or hints on where the water is comming from I would appreciate.
Thanks, George
F-I-T
09-04-2003 06:41:50
 Re: 48 A water vapor in reply to George K, 09-02-2003 19:01:39
George:
FYI, there are some shutters for your "A" for sale in the "Photo ads" on this site.
Frank
Clooney
09-03-2003 03:45:14
George, those old 2-cylinder Deere's have lots of places in an engine & trans that water can get into & hide. In the trans, the space outside of the differential bearings is a good place for water to hide until it is washed out with trans oil during use. In the engine, the governor, rocker cover, 1st reduction cover are good places for water to hide. [try to drain the 1st reduction cover]
~With you using antifreeze & the water being clear I would suspect you still have rain water in the engine & trans.
~Probably most of you trans water will work it�s way to the bottom of the trans with use & on the engine it will burn out if you can get the engine up to operating temp for a couple of hours. Just idling it around or driving it on the road won�t get it hot enough.
George K
09-03-2003 13:05:14
 Re: Re: 48 A water vapor in reply to Clooney , 09-03-2003 03:45:14
Thanks, JDC, I'll crack the 1st reduction gear cover and see what drains, hopefully I won't damage the gasket and have to pull the belt pulley/clutch to replace it. Governor and rocker cover should be easy, and I can check the valve clearences while I am at it.
The next question is where does the water get in? Both the tranny and the crankcase are pretty well sealed (in theory, anyway). The crankcase is vented via the fan tube and the vent tube. All else is gasketed except around the belt pulley. How does the tranney/diff get vented? or does it?
Looks like I have a magic tranny. . . put 50 bucks worth of oil in it, and it turns to chocolate milk!
Guess I will just have to go disk some more in a high gear. Should be able to block off part of the radiator to help the heat (no shutters). That should get the water out of the crankcase.
Thanks for the information
George
520-LP
09-03-2003 18:16:43
 Re: Re: Re: 48 A water vapor in reply to George K, 09-03-2003 13:05:14
Should be a plug in the reduction gear cover at the lowest point under the right brake.
George K
09-05-2003 15:15:12
 Re: Re: Re: Re: 48 A water vapor in reply to 520-LP, 09-03-2003 18:16:43
Thanks for the info;
520-LP: This one does not have either the drain or the filler on the reduction gear cover. That was a later change, came out after my serial number, at least per the parts book. I will just have to loosen the bolts a bit, and pry the bottom a little to see what comes out. If I ever take the cover off, I will drill and tap for both plugs.
Thanks, George
720Deere
09-03-2003 17:09:27
I have found that a worn clutch shaft makes an excellent entry point for water. There is no real seal there anyway and a little bit of wear makes it alot worse.
George K
09-05-2003 15:20:17
 Re: Re: Re: Re: 48 A water vapor in reply to 720Deere, 09-03-2003 17:09:27
720Deere: Yeah, I looked at that clutch shaft, and altho it is not really worn, there is some slop in it where water could get in. Looks like the only way to keep it out is don't let it get wet!
Thanks, George
