2510 Value
chris
01-18-2004 19:31:53
This tractor has been under a lean to for 17+ years and hasn't moved/ran, has been repainted, schwartz wf, 3pt, single hyd., one new rear/one useable tire(15-38) and same with front tires, light duty loader/pto pump, heat houser, delco alt., cast iron carb., don't know if it's stuck and the weep holes are leaking. chris
I've got one too...
01-19-2004 03:56:30
 Re: 2510 Value in reply to chris, 01-18-2004 19:31:53
I have a 2510 with JD widefront, F11 Farmhand with grapple. New rear tires within the last 5 years. Hasn't been started in over a year. I'm going to try to get 2000.00 this spring.
HOOSIER
01-19-2004 18:03:39
 Re: Re: 2510 Value in reply to I've got one too..., 01-19-2004 03:56:30
WHERE ARE YOU LOCATED-I'M FROM NORTHWEST INDIANA
HOOSIER
01-19-2004 18:00:34
