JD 420 final drive
Bruce
09-02-2003 18:25:03
I need someone to go through the procedure for pressing the axle out of the bull gear on a 57 JD 420-W
Wayne in Tn.
09-03-2003 08:57:42
 Re: JD 420 final drive in reply to Bruce, 09-02-2003 18:25:03
Bruce, since no one else has replied, I will take a stab at it. The service manual says to remove the 2 bolts and washer on the end of the axle. It refers you back to the 40 manual and a 40 has a snap ring in front of the bearing, but I don't believe your 420 has the snap ring. Then it shows using a big puller, hooked into two holes in the housing beside the axle end, and then using a big hammer on the end of the puller. I have never owned a puller like that, so my way is to use a big brass drift or punch and whack the end of the axel. This has always worked for me. Usually they are not stuck too tight. Just be careful not to bust the housing.
