4020 MFWD
Mike
09-02-2003 13:46:40
Any one know any thing about a 4020MFWD. Did thay work ,can you get parts for them?Are thay worth any thing?
Loren
09-02-2003 20:00:38
 Re: 4020 MFWD in reply to Mike, 09-02-2003 13:46:40
There were some mechanical front wheel drives. Have seen a 4020, IH 806, and MM G1000 with mechanical. Had the drive shaft running from the rear. Guy just down the road still has and uses his 806 with the front drive.
Mike
09-02-2003 15:41:31
Its not Mechanical, its hydraulic. They did give some assist, but its not the same as MFWD. They were prone to electrical problems(switches on clutch,shifters etc)and leaks. Alot of people(me included) switched the legs on the front end to standard 2wd spindles and capped off the lines. Parts are available (seals lines,bearings etc.) but if the hyd. motors are bad they can get real pricey to fix. Some people are starting to make these collectable as they are a little odd,not so much on the 4020's but the 3020's are rare.
Mark
09-04-2003 18:20:54
 Re: Re: 4020 MFWD in reply to Mike, 09-02-2003 15:41:31
Sorry but there are mechanical ones. On IH were driven out left side of trans. housing and are seen from time to time. I know of 6 in county now. 4020 was driven from top of trans. housing and had to chop operator platform. I have only seen 2 in my lifetime. Wish I could find one now that subject is being addressed.
Mike
09-03-2003 06:05:42
I'v seen hyd front ends but this one has a drive shaft.
