Clooney about that leak on my styled D
Dan the D man
09-02-2003 13:00:16
Clooney,
As you ask in you r last resond. I can tell you the exact RPMs but it was pretty low. When i idle up the tractor it got a bit better but not good. I have a DLTX 16 carb would that be the problem or do i have to take the carb off and clean it. The leak that i think i found is in the middle of the manifolds so I'm thinking that its the intake manifold right?? If its not the intake manifold that has the leak how would I check for leaks?? This winter hopefully i will get the proper carb for it then i won't have all this trouble HAHA.
Thanks
Clooney
09-02-2003 18:31:43
 Re: Clooney about that leak on my styled D in reply to Dan the D man, 09-02-2003 13:00:16
Dan, that DLTX 16 should work ok as long as it is functioning correctly.
~To check the manifold for leaks turn the flywheel until both exhaust valves are closed, then seal & blow compressed air into the exhaust system [you will soon find the leak]..Then do the same for the intake, pull the carb, then turn the flywheel until both intake valves are closed, then seal & blow compressed air into the intake at the carb mounting area [again you will soon find the leak].
~You could also have a carb problem, while the carb is off the tractor pull the float bowl, then pull the load nozzle out of the carb & make sure all the little side holes are open. To pull the load nozzle- just run a tap that will fit about 1/4" into the bottom of the load nozzle, then install a proper sized piece of all-thread with a stack of washers & nut..Just tighten the nut on the washers to pull the load nozzle out of the carb stem.
~You could still have other carb problems but the above is a good place to start. ~You will probably have to eliminate the manifold leaks before you will be able to tell much with the carb..
