unstyled A questions
Scott M
09-02-2003 12:07:44
Just bought a 36 A. Steering has half turn of play. Previous owner says it needs shims. Where can I find some? Also need fuel control valve next to fuel bowl(3-way/Fuel,gas,off). The petcock?(compression release) on the right side seems to leak a little. Is this normal? If not, where can I find one? Thanks, Scott
Mark
09-02-2003 20:34:06
 Re: unstyled A questions in reply to Scott M, 09-02-2003 12:07:44
Scott, you can buy new compression releases,
and that 3 way fuel selector from Deere.
KrisA
09-02-2003 14:00:32
I had a couple tractors that had that much play in the steering and found that it had no bearing at the very end of the shaft. Got new bearing and took care of problem! My .02
krisA NC
deereman
09-02-2003 13:13:03
On your petcock just push in on it to the left when you push it down to close it. This should stop some of the leaking. It worked on my 1937 and 1944 A.
Scott M
09-02-2003 13:24:43
 Re: Re: unstyled A questions in reply to deereman, 09-02-2003 13:13:03
Thanks
