1530 charging system
Scott
09-02-2003 07:26:57
Bought a 1530 Diesel. Alternator is not charging. It's a Bosch with an external regulator. Temporarily installed a Delco automotive unit. JD Dealer wants $230 for an alternator and $75 for a regulator. Wow! Would like to keep the tractor original. Manual gives three test procedures for the system. This one failed two of the three which says there is a dead short and bad diodes. Doesn't say how to isolate the regulator. Any suggestions for a cheaper repair and determining if the regulator is bad also. Also the alternator light does not come on. The light is good and wired correctly.
Thanks, Scott
david val
09-02-2003 10:32:44
 Re: 1530 charging system in reply to Scott, 09-02-2003 07:26:57
in the mannheim tractor system (where bosch alt. is used) there is a light blue lead that comes from the lamp holder to the D+ terminal of the regulator and from there to the D+ terminal in the alternator. if you ground this lead with the key switch on, the alt. light should come on.
from your description, it seems your alt. is at fault. you can try to have it repaired or get a rebuild.
if you get a rebuild, it will probably be a higher capacity alt. nothing wrong with this. make sure you get the right pulley (for 'b' belt), if not, you can transfer the pulley from the original alt. it will probably also have an internal regulator. you can use it and connect the D+ lead from the connector to the D+ terminal of the alternator or, if you want to keep the original configuration, you can replace the regulator/brush holder of the rebuilt with the original brush holder after replacing the brushes. this will also help in determain if the regulator is ok.
david
Scott
09-02-2003 10:40:05
 Re: Re: 1530 charging system in reply to david val, 09-02-2003 10:32:44
David,
Thanks for the info. I grounded the light and the light works. What I don't understand is why the light does not work with the alternator connected. If I get a unit with the internal regulator, then the D+ wire would be the only wire I connect, right?
david val
09-02-2003 13:35:28
 Re: Re: Re: 1530 charging system in reply to Scott, 09-02-2003 10:40:05
the light doesn't come on beacause the alternator is shot, and yes the D+ lead will be the only one (except, of course the output lead B+).
david
