HYD FILTER STOPS UP ON JD 2640
PAT
09-02-2003 06:21:22
I HAVE A JD 2640 WHOSE HYDRAULIC FILTER KEEPS STOPPING UP. I HAVE CHANGED THE FLUID BUT SOMETHING SEEMS TO CLOG IT AND STOP THE FLUID FROM GETTING TO THE FRONT PUMP. WHEN I CHANGE THE FILTER THE TRACTOR WILL WORK PERFECT FOR A COUPLE OF DAYS THEN STOP AGAIN. THE SCREEN BEFORE THE FILTER IS VERY CLEAN. I WOULD APPRECIATE ANY HELP.
THANKS
PAT
Brokenwrench
09-02-2003 12:55:17
 Re: HYD FILTER STOPS UP ON JD 2640 in reply to PAT, 09-02-2003 06:21:22
The tractor most likely needs brakes. The filings from metel to metal contact are very small and clog the filter quickly. The more you run the tractor the more likely you are to pump contaminated oil into the steering, brake,remote, and 3pt valves causing you many more problems than you have now. After replacing the needed brake parts it will take 3-4 CLEAN UP filter changes to rid the system of all the metal paste that has built up in the lines, valves,pump etc. Then you can change the oil and filter (regular hyd. filter) and resume normal operation.
PAT
09-02-2003 11:20:25
THE STANGE THING IS THAT THE SCREEN AND FILTER LOOK CLEAN, MAYBE JUST A LITTLE DIRTY. I HAVE CHANGED THE FLUID TO AN APPROVED SUPPLIER. IF IT IS THE BRAKES WOULDN'T YOU BE ABLE TO SEE SMALL PARTICLES IN THE FILTER? ALSO HOW IS THE BEST WAY TO FLUSH THE ENTIRE SYSTEM?
david val
09-02-2003 13:51:05
 Re: Re: HYD FILTER STOPS UP ON JD 2640 in reply to PAT, 09-02-2003 11:20:25
if it is brakes you will be able to see metallic 'clouds' in the oil and there will be metal in the filter cup. best way to check is with the magnet.
if the system is contaminated with metal from a brake failiure, i'm afraid flushing will not be enough. the fine metal sawdust passes the filter and fills the whole system. if it's going on for a long time you can get 3/8 thick layer of steel dust at the bottom of the transmission.
the way to do i right is by disassembling the transmission and all hydraulic components and cleaning them individually.
david
david val
09-02-2003 10:51:31
what do you mean "the screen befor the filter"?
if it is the suction screen at the bottom of the transmission case, then remove it and insert a magnet in it's opening to the case bottom and see what comes out. if you get metal sawdust all over the magnet, then its probably worn brakes. if it's clean and the filter cup is also clean, you may have a problem with the oil type or with the filter relief valve (located just above the filter.
david
cannonball
09-02-2003 06:32:06
sounds like you have brake problems...water in hyd fluid causes the lining to come apart and then you have metal filings in oil...will stop up filter pretty fast...better plan on checking brakes....hae nice day may god bless
JDGnut
09-02-2003 09:32:24
 Re: Re: HYD FILTER STOPS UP ON JD 2640 in reply to cannonball, 09-02-2003 06:32:06
I'd agree.. Look at the material in the filter.. Also there should be a pick up screen (wire mesh) that should be mount cross ways transmision/rearend housing... on the later tractors it was a hex plug on the right side.. I can't remember on the 2640's... But drain the oil.. and you should have more indication about the metal and fibers inside... (If you drain it.. pull the pick up screen and at least clean it..)
JDGnut
