Dual Touch-O-Matic frozen
tom
09-02-2003 05:27:09
Howdy,
All of the arm lifts do nothing when I move the control knobs. So I loosened the nut of the small line [from the pump] that goes into the touch-o-matic and it pumped oil out...the oil didn't squirt out, but was kind of oozing. I had the tractor in neutral in low idle.
Question is what do you guys recommend I do next? Do not know when the hydraulics worked last so I have no reference point. Changed the fluid when I bought it 6 months ago, and refilled with 10W oil to the spill-over valve before I tested.
Any advice would be greatly appreciated.
Thanks, tom
Wayne in Tn.
09-02-2003 10:23:45
 Re: Dual Touch-O-Matic frozen in reply to tom, 09-02-2003 05:27:09
Tom, I take for granted you are talking about the MT. First, I would loosen the line again and open the throttle up about half way, or wide open, you should get a squirt of oil 5 or 10 feet, if so this will eleminate pump problems. I know this is not a real techicnal test, but I am assuming you don't have a 2000 lb. pressure gage. Once you have determined the pump is ok, then check the big line (suction line) for pin holes or bad seals, it can be sucking air and is hard to find. Once all this proves to be ok, then its time to get out the parts and service manuals and go into the lift unit itself. You will need these manuals in order to identify parts and procedures. First remove the check valves, inspect them for burrs or trash, if you find a problem here, you may not have to tear the unit down. If no problems found yet, then tear the unit completely down to where you have the 3 seperate housings laying on the workbench. Now is the time to replace all seals, o-rings, head seals and piston seals, while you have it all apart. All the parts will run about $150 from Deere, you will have to use your parts book and order each part seperate, they don't offer the rebuild kit as a kit anymore. Two important things to keep in mind: Cleanliness .. and always remove the check valves FIRST and install them LAST or you will damage them when putting the control valves and housing back together. Also I would hone the cylinder walls, just like you would in an engine.
tom
09-02-2003 13:39:47
 Re: Re: Dual Touch-O-Matic frozen in reply to Wayne in Tn., 09-02-2003 10:23:45
Thanks Wayne, yes this is the MT...your assistance will get me back to the testing bed.
When I test the pump again, do I open her up to 1/2 WOT or greater, then open the line or can I have the line open b4 I start it and open it up? I guess what I am saying is that does the small line need to remain closed for sometime[?] to build enough pressure b4 you open her up?
If the pumps proves to be bad, then do I get the kit that replaces pumps gaskets/seals?
regards, tom
Wayne in Tn,
09-02-2003 14:37:36
 Re: Re: Re: Dual Touch-O-Matic frozen in reply to tom, 09-02-2003 13:39:47
Tom, I would loosen the fitting while the RPM's are up, this will give a fair test of the pump. The service manual calls for testing at one of the pipe plugs on the lift unit, with a high pressure gage. Without looking it up, I think the pressure should be around 1200 to 1400 lbs. This is just a poor man's way to see if the pump has pretty good pressure. As to a pump rebuild kit, that is not available at Deere as a kit, you have to order each part seperate, usually surfacing the pump halves, replacing 4 bearings, 2 big o-ring seals, mounting gasket and the shaft seal and o-ring.
I have had better luck just to completely tear down the lift unit, clean and inspect, replace all (soft) parts. instead of trying to diagnose one particular problem. Those systems don't have a filter and usually are full of crud and the piston and head rings are usually shot. In the past couple of years I have rebuilt 6 of these units and had 100% success.
Again, I would caution to not attempt rebuilding the pump or lift unit without the parts and service manuals. There are several tolerances that must be followed when installing bearings, ect.
tom
09-03-2003 05:40:34
 Re: Re: Re: Re: Dual Touch-O-Matic frozen in reply to Wayne in Tn,, 09-02-2003 14:37:36
Wayne,
Thanks again for your advice. If you have restored/reworked 5-6 of these T-O-M's, then you must "have it down pat" by now.
I will try the worked up some steam first, then remove the pressure line @ the TOM. If I get a good squirt, then I know it is the back-end of the unit somewhere. I noticed in the breather cap that it was plugged with grease and I pulled-out some [or all] of the copper mesh that is in there like in the oil breather cap...I replaced that old wool with in the oil-breather with a hand-scrubber made of copper wool and it looks/works great. Can you replac this stuff from the inside of the TOM, because the hole from the outside is too small and I can not see what is in there anyway.
Lastly, I agree with you that the whole unit should be removed, inspected, cleaned, all soft parts/worn/damaged replaced. In your experience Wayne, what parts for the pump and main body should I order and I will do so. IF there is a list of them somewhere, then let me know and I can gather them and you can verify/validate. After your review, I will be prepared to write mother-deere a check and get them on order.
Thanks again for your assistance...I wish TN was much closer to TX !!
Regards,
tom
