D Flywheel
JC
01-18-2004 18:09:36
Is the 'pin' that drives the flywheel spacer threaded into the flywheel or is it pressed in? Mine is very worn down and I'm trying to remove it.
Thanks,
JC
JC
01-19-2004 04:51:07
 Re: D Flywheel in reply to JC, 01-18-2004 18:09:36
Thanks for the information!
I was rushing to get this work done and I didn't look carefully enough in the parts cat.
Regards,
JC
Walt
01-18-2004 20:50:18
I just finished an identical repair I drilled mine out. the new part number is D2009R.
Duane Larson
01-18-2004 18:39:49
JC,
It's pressed in. If it's hard to remove, flatten the remaining surface, drill and tap for a screw, and remove with a slide hammer and vice grip.
