2010-2020 engine swap?
Steve
09-02-2003 04:30:51
will a 2020 eng fit a 2010? I'm looking for a eng for my 2010
and I'm starting to think I may have
more options
HTR
09-02-2003 08:50:53
 Re: 2010-2020 engine swap? in reply to Steve , 09-02-2003 04:30:51
The 2020 engine will not fit. The 145 from the 45 is pretty much a bolt in chage over, after changing some accessories. The HA145 will fit, but is not a sleeve and deck engine. The HB, Hc145 etc. are deck engines. You will have to use the oil pan and maybe the oil pump from the 2010.
buickanddeere
09-02-2003 19:02:08
 Re: Re: 2010-2020 engine swap? in reply to HTR, 09-02-2003 08:50:53
Could you expand on the those different 145 engine terms please?
toddt
09-02-2003 04:59:26
Steve, I see your earlier post asking about the 45 combine engine as well.
Several years ago I helped a friend replace an engine in a 2010 that had a cracked block, but the cylinders and deckplate were good. He'd also heard that a 45 combine engine would work.
Our research and a trip to the local farm junkyard turned up several interesting things. The 45 combines used three different engines, one which was a Hercules, and two different Deere engines. Both Deere engines had the same block number, but were not the same block. I don't recall the exact details, but there was something about looking at the water jacket covers on the side of the block that made the difference obvious. (I think one block may have had removable covers and one didn't.)
As we continued scouting around the junkyard, we happened to look at the engine in an old hay swather. (Model 415? 437? It was in the 400's.) It had the same engine, and with a lot fewer hours. Took the engine home and pulled it apart.
The exhaust had not been covered, so water had filled the cylinders and broken them. Also, the pistons were no good. But the block was whole, and the cam and crank looked like new! Used the deck plate and removable cylinders (which is all one piece) from the old engine, and the block, crank and cam from the replacement engine and put the old girl back together.
To answer your question - Yes, there are other options than just a 2010 engine.
