crankshaft spline machine rebiuld
Jonesy
09-01-2003 20:09:37
I am preparing to restore my first JD. It is a 49 A. Ive been reading books and what not trying to find out as many tricks of the trade as possible before starting. In one book it says that due to "work hardening" on the crank splines you must have them turned, built up and re cut so that the flywheel and pully run true. Have any of you had this done before? Im wondering what kind money that would run into and is it really nessasary. Thanks
Lee
09-02-2003 03:11:07
 Re: crankshaft spline machine rebiuld in reply to Jonesy, 09-01-2003 20:09:37
I'm thinking Adam's estimated cost to him of $200-$300 should be considered a bargin. No doubt others have had the same work done for far less, it's still a bargin at $300.
Neccessary depends on your crank's condition. Flywheel fix is often just a matter of replacing soft, stretched bolts with grade 8 and 'putin' the torque to em. If it won't stay put then, that's when you need the machine shop.
Work hardening is not a reason to rebuild the splines. Worn off is the only reason to rebuild the splines - it sounds like the book you're reading would also demand that one drain, flush, and replace anti-freeze yearly. Go ahead and finish reading it, but ignore everything between the front and back cover as not even the author could afford his own advice.
Adam B.
09-01-2003 21:00:56
The crank from my '39 B has badly worn splines on the drive end. The leading edges are rounded over, and the trailing edges have a burr along them. I took it to a machine shop to be welded and cut back to original size. I'm still waiting for the work to be completed, so I can't say how it turned out. The estimated cost is $200-$300, dependent upon how long it takes him to do it.
In my case, I determined this needed to be done. The splines inside the clutch driver appear to be in great condition, but with regular use it appeared the crank splines could round off entirely. That would have put the drive disk at risk of damage as well, and call for another engine tear down later on. The driver is being used as the pattern for the repair, so the splines should match perfectly when its done (even if the driver is worn some). I'm planning to use the B regularly to for some hay raking, miscellaneous projects, and an occassional tractor pull. Its also expected to make several HP over stock, so it wasn't worth the risk to put it back together already worn like that.
