Bleeding M Hydraulics?
Neil Holliker
09-01-2003 18:33:54
Put some new gaskets in TouchoMatic control unit, now rock shart comes up real slow and then bounces up and down when it is at top.
Can't figure out how to bleed the air from the system. Can anyone assist?
Neil
Bus Driver
09-02-2003 04:30:32
 Re: Bleeding M Hydraulics? in reply to Neil Holliker, 09-01-2003 18:33:54
Have never experienced any problem with air in the M hydraulic system. The linkage within the hydraulic system housing is critical. Was it reassembled exactly as original?
Wayne in Tn.
09-01-2003 18:45:20
Neil, those systems usually bleed themselves. There is not actually a bleeder plug or anything. Normally just raising and lowering them a few times will do the trick. You might try loosening the high pressure line at the front of the housing (small line) while the tractor is running and let it squrit out some oil. This is messy, but is the only way I know of bleeding them.
